recentered h1 wheels, to fit or not to fit?
It's time for new tires on my 2000 , i was wondering how many people have the h1's With military 37s on their dodge s, if so how much lift was needed, ive heard a leveling kit and they fit, but want to make sure before i spend the money.
  • Replies 2
  • Views 1.7k
My understanding is that the only thing that is required to make H-1s fit is the center hole needs to be made slightly larger. I am not sure about the lift requirement for putting 37" tires on though
i run 35's on mine with a 2" level kit and i get rub on lower arm at full turn. you will rub a lot with 37's and either a lift or fender trimming by the door and spacers to not rub control arm
