- Replies 19
- Views 2.6k
Marc_4x4 7 posts
Yankneck696 6 posts
diesel4life 5 posts
rancherman 1 post
I a got a weard probleme and i discoverd that my truck on paper is a 2001 and on the door the fabrication was 03/13/00 is that normale?
so when the truck was fully original those it have the 2001 block that only run a cam sensor?
My trouble i got a p0341 and i cheque all what you say to cheque on the your obd11 test twice and i see nothing. So before changing the ecm or the vp44 because every body says its should be that But it a very expensive test!!!
I got a few question before i discovert that the block have been swap the cummins block is a 98.5 with a ecm 00 And the wiring that plugue the block is like 01-02 because i have no unplogue wire and the crank sensor on the block just beind the starter is unplogue.
So can this be my trouble off being in (limp mode) i got a Block that supose to be working with a cam and crank in 98.5 and the truck wiring supose to be running with only a cam. Can my trouble be that the cam gear between the two years is reding a différentes thing?
Those anyone have the picture off the two cam gear and can i just change that and the truck will stop being in limp mode
