clawdog60
  1. previous owner/s must have removed the exhaust valve because its not where it should be, oh well will just have to be extra careful with a big load in the mountains (unlikely for me) besides I have a six speed. Plan ahead!
  2. Passenger side firewall next to AFE intake I have a solenoid with a green and yellow wire to it, it has a vacuum line (I think) to it and a exhaust muffler. Can someone tell me what it is and what function it performs.
  3. The deutsch connector company website.
  4. Not trying to hi-jack the thread but, this weekend I tested my block mounted lift pump, I pulled it off the truck and jumper wired it to check pressure, the pump has a red and black wire fromthe pump side connector. I thought the black was ground, black from the engine side of the connector is ground, ran the pump and no pressure, reversed the wires and BAM 26 psi. I purchased the truck used and don't know the history but the pump wiring is reversed and could never have put out any pressure/fuel. So black is positive and red is negative on this block pump.
  5. Has anyone repaired a terminal on the female side of the plug. Deustch connector. I have looked @ the website but I didn't find the repair of that 50 pin connector.
