Cummins1401
Everything posted by Cummins1401
  1. Ill try tomorrow after work. thanks
  2. New starter contacts. batteries less than a year old. Had load tested. Jumped all cables. Cross over and grounds with jumper cables. To check wires. Any suggestions? Maybe have starter bench tested
  3. @DieselfutureI to would like @dap to elaborate on that. I was told by dap that I would have to start fuel trim at 85-90% at 0psi to stop smoke. But 150 injectors only flow 80% of fuel vs stock injectors? Definitely banging my head right now. @DieselfutureI'm not looking to roal coal every where I go. Want a clean powerful daily. at this point I'm wishing I kept stock injectors and just put the quad in. Just want to figure out why it wants to stall when put in gear. It's not the tc. Barely any engine load sitting still in gear. If I get on the skinny pedal quick after putting in gear I get one quick buck then all the power is there. If I just put in gear and hold breaks it lopes bad. Let off the break it starts jumping rpm up and down until I give it gas then it settles out. Thanks @DieselfutureMaybe I should start fuel at 120% if there only pushing 80% vs stock lol.
  4. @Mopar1973Manquick summary. Bought the truck mid winter. started really rough and smoked until warm. Noticed the battery guage didn't drop when grid heater solenoid clicked. Bought it for a decent price. Sure enough the grid heater solenoids were bad. 75$ later truck was turn key. 30 k on rebuilt trans stock stall converter have the paperwork. Had slight idle haze and could smell the unburnt fuel. Driving there was no smoke good pedal response. 217k on stock injectors 1 owner truck. so I bought the dap 7x.0010 dap vco injectors. Quadzilla adrenaline. Bd stealth cover. installed all at the same time. Quad on stock setting just to see fuel pressure. fass titanium 165 gph fuel is fine. 150 injectors no smoke on stock tune. Even removed quad. no smoke driving like I stole it lol. And obviously now loping idle wanting to stall only when put in gear for the first time unless I put in park and put in gear again. Going to take it to work tomorrow and just turn it right up for the first time and see what happens. a stock truck with 150 injectors should have some smoke. Maybe being at sea level and building my own true 4" Id intake gives enough air? Vp is reman 3 years as ago maybe getting weak? Maybe bd stealth cover tap screw over tightened? I have 12.3 volts. Any more insight would be appreciated. Alot of good help on here. Thanks again.
  5. Thanks @Mopar1973Maninjectors re installed yesterday ran out of daylight primed and started up today. initially installed primed up in like 30 seconds after installing. This time it took about 5 key bumps to get fuel to cylinders 1 3 4 and 5 to start. Same symptoms. Maybe my vp is getting weak after bigger injectors.
  6. So I got the injectors back today. When I Originally called and explained my symptoms and asked what pop pressure they were set to I was told they were set to 310 when I called. Spoke with dap Friday to check on status. Was then told they all tested within 9 psi of each other witch was still in spec but they lowered a bit and should help. Get them today with test results and they all tested 289-299 range and now there set to 290? Stated on test sheet ac problem,programmer problem,or weak vp. I told them I had a ac bypass belt on. Vp is reman and I had disconnected the quad. no problems since swap. Is 290 ok? Seams a little low to me. Thanks.
  7. That's what I figured. I had a 1998.5 like 10 years ago no tune and bigger injectors. not sure what company but was told 100hp. It too smoked like a frieght train. So yeah I bet a problem with injectors if I can't get a puff with 150s thanks @dripley
  8. @dripleyI guess what I'm getting down to is should 150hp injectors smoke on no tune even with quad removed? I assumed yes on the low end until turbo spooled. But nothing combined to bad idle under load. @dripleyDid your 275s smoke with no tune? That's what I'm getting at. 150hp injectors zero smoke before any tune.
  9. I plan on it. That's why I got the quad.i want zero to minimal smoke vs power. Was planning on getting 275s but was told by jkidd to get 150s to grow into knowing bigger turbo in future. and start tune at 85ish at 0 psi for no smoke. Then after bigger turbo Turn up. Said stock tune would smoke a lot on the low end. Was just wondering why no smoke no matter how hard I try. Hopefully they find a problem to explain that's related to my problem main problem. thanks @dripley
  10. Injectors are in the mail. hopefully they find something. I've had zero problems with the truck except grid heater relay. since the stock trans rebuild 30k miles ago. I have a spare trans I picked up to use as a core for a fully built in the future as needed with the added power. Have head studs ready to install. Planed to order a bigger turbo last week as well but wanna figure this out before I do any more work to keep the possible causes to a minimum. any recommendations on a good tranny setup or turbo size? Thanks. Also the 7x.0010s vco had zero smoke on stock tune. Can bus 100% across the board. Wot up steep grade nothing Maybe they will find a problem to answer that. Maybe being at sea level I should have went bigger?
  11. Thanks @dieselautopowerkaycee will be getting an email shortly with tracking you will have them Wednesday.
  12. Pulled injectors today to be returned to have pop tested and noticed 3 of the copper washers are slightly thicker and slightly larger in diameter than the other 3. I still have my old ones and all 6 look like the smaller ones. Could this be the route off all my problems?
  13. I spoke with kaycee. He's taking care of me. Thanks.
  14. They are vco. Said they were set to 310 bar. They look like they have been rebuilt alot.
  15. After purchase of dap 7x.0010 injectors and quad I'm having idle issues first time put in gear. 99 auto stock hx35 cai 4" mprp big loap will stall if grid heater is active. Smokes when grid heater is active and in gear. If I double pedal to back out I'm fine. Once in gear im fine until I put in park again. then same problem. I've completely removed quad ran on zero ran on 3 with timing changes. No change. Ran wire tap with ZERO SMOKE all settings. After researching alot on here I assumed I needed the quad to turn can bus fuel down on no to low psi for smoke control. I'm stumped. any advice. thanks Stock stall converter. fass set to 14 psi. hits 15 when bucking in gear. 12 min at wot Apps is in spec vp is reman 3 years ago. Trans has 30k on stock rebuild. 221k on stock injectors. no problems until new injectors Tightened tubes to 28 ft lbs hold down 89 inch lbs. No change in oil height. Quick bleed started in 5 seconds after bleeding.
