Veridical1
Everything posted by Veridical1
  1. if you have stock lines they will move alittle, if its upgraded lines i would hose clamp them but make sure not to cut them, also make sure your tank vent is not clogged or it will have starving issues
  2. i would highly recommend the outerwears filter cover, very easy to clean and saves you from replacing the filter
  3. make sure to use a boost bolt if its a mechanical boost gauge.the trans sender going on the passenger side of the trans in place of a little plug toward the bell housing.
