duesman
Everything posted by duesman
  1. I also live in the rust belt they go nuts with that liquid stuff on the road I use an old lawn sprinkler that spins with adjustable nozzles stick the garden hose under the truck in the front get it to the back attack the sprinkler turn on water pull the hose very slowly forward and it washes the salt off the underside
  2. I thought they were made in the USA I didn't check my spindles to see where made my friend retired was a engineer who bought spected out parts from china he would get his parts made in china he checked the parts and they weren't to his spect he called and talked to the company about the problem they told him the parts were GOOD ENOUGH he told them he needed the parts with tolerances on the spec they said 6 months to ship the make & ship the parts so he used the parts cause he was running out of the parts so maybe my spindle parts were GOOD ENOUGH
  3. Yank neck 696 what kind and how much 2cycle oil per gallons do you use I would like to try some now I use stanadyne it increases my fule pressure 3or so lbs I am open for sugestions on your mix
  4. I had my front spindles and ball joints replaced last year I bought Moog ball joints and Napa spindles after 2weeks of driving my antilock break light came on Thursday I bought a new wire to abs sun we started to replace the wire we pulled the sensor out the long part was half chewed up we looked in the hole the sensor came out and noticed little chips in there we pulled the year old assembly off (thank god they used never seise) the outer race was cracked in 3spots its Sunday called around found one bought it$330 put it on with new wire that came with it abs light went out brakes work fine Mon took old spindle to Napa with receipt they gave me a new one now I have a 330 spare just my Esperance just cause its new don't mean its good
  5. I just change my motor oil and check my air filter my truck is totally stock 2002 154000 miles opacity last time 1.3 same thing time before I livein ct
  6. did you change the switch yet i'm going to test the pins of the multifunction switch with a multi meter according to the book shortly
  7. sounds like a good guage did you buy it from a vender on this site the auto stores around here are ok but i would like a guage that is reliable not like my first lift pump ( just cause it's new don't mean it's gonna work)
  8. i'm no mechanic but the book say's remove negitive terminals on batteries first (air bags won't go off accidently) while working it looks like its a component which includes your turn signal lever ps book say'syou need a tamper proof torx bit that secure the screws for holding multifunction switch to the steering column
  9. i'llcheck the multifunction switch i checked fuses under hood and in cab ok held wipers while on no smoke yesterday i had wipers on when i stopped them they stopped right in there tracks no return to cowl i have to turn off when at cowl
  10. it was definetly smoke i opened the windows after that i went to my auto parts store on the way home and bought some air freshioners right now i took it to my friend with a heated garage and he is going to look ar it tonight im going to call him to make the proper fuse is there thanks for the info also i was thinking maby a bad ground i'm no mechanic when i find out i'll be back
  11. i turned on wipers to clear ice from windshield i freed the blades 5 min previous the wipers are off i turned them on now they iced up and smoke came from the dash i turned them off immediately the smoke stopped i free'd the wipers everything else in the dash works any suggestions would be greatly appreciated as soon as it warms up a bit i'll try to find the problem thanks
  12. i had the same problem right after i bought my 2002 i had my truck checked bad injector and lift pump had those replaced and a idiot light installed in the post after 3 months the light in the post came on for a few seconds every now and then had the sending unit replaced same problem accured had a mech guage inslalled with copper tubing same problem but this time the pressure guage read 3psi with the light on thepost on the guage shot up to 12psi the light went out at 5 psi i had the lift pump replaced only a year old with a fass ddrp02 no more drop in pressure perfect so far 9 mo later
