skymaster
  1. hello fellows, i just changed the injecores in my 2000 and am courious if the injectors are seating totally down into place?? the injector rocker arm type ?? support is not showing much progress going down after 25 inch pounds tourqe ( (b4 the finished tq at 89 ? I believe) it appears theres approx 3/16 in befor the hold down bracket would b flat against the head , I did not notice this gap when taking the old injectors out , any one know if this is right or wrong pls let me know befor i finish, Thanks Guys
  2. i will b double checking for vacume line connections , ill need to find a diagram thow, thanks , ill keep u informed, And i'll work on a video for ya :-)
  3. Im corn fussed ?? replaced the injector pump and now i have an issue with excessive oil blowby ,its seems i need to be going better then 55 for this to happen ? any suggestions were i should b investigating first, thanks .
