turbodude51
  1. Talking to a Cummins engineer years ago he said the VP was never designed for that size engine, after going through three of them, I P Pumped, I can start my truck just like the VP by reaching in and turning the key, I can adjust fuel without a programmer, I can run it out of fuel and just be stuck, Ill never go back and not sorry one bit I did, and its a daily driver Rick
  2. I bought a billet tappet cover on e-bay which was tapped 3/4 NPT, used Right Stuff gasket maker ran two lines to a catch can also bought on e-bay which has a site tube and drain. Valve cover also has to breathers all to keep pressure from building up
  3. I just pulled it off to replace O ring, but I modified it a lot! Rick
  4. I am new to this forum, and do all my own work. I own a P pumped 2002 dually that is also super chargeda work in progress. Everything on this truck has been modified except the crank! Looking to find information on my P pump which has been modified by me alreadyin circle in front it says 908then:PES6P120A120RS7416then: 0402736906Then: tag on rear: RQV400 1250PA1060-4K392 8146 0005I know some of the info but Mike said to postThanks in advanceI am also able to answer or help anyoneRick
