dayne808
Everything posted by dayne808
  1. i bought an airtex pump and the pressure at WOT is like 12 psi but it idles really high at like 20psi. not really liking the pressure drop, but i guess i'm in the safe zone. with normal driving conditions it stays up in the 15-17 psi zone. i plan on buying an airdog or fass later even though my truck is just a DD, i rarely tow anything (sadly yes) i also agree with you guys about the importance of good press. i'm sure if it gets below 10psi on occasion it might not hurt the vp44, but steady romps on the throttle with no fuel pressure monitoring can lead to disaster hahaha
  2. mine will say p-done twice in a row. i actually had issues with the tranny unlock/lock, i never actually rewired the apps ground.i just removed the battery cable. just re-grounded it, hopefully it will work.... seems like its a throttle response issue. i'll let you guys know how it goes. thanks
  3. i changed the filter and it still feels the same. i already changed the lift pump to a "stocker" (airtex E7153) but will prob. change it to an airdog100 later. not looking to boost power to much, maybe to pull 35's (i have a 5" lift sitting here) i don't tow much maybe a mini excavator or skidsteer once in a blue moon. just want it to be reliable.
  4. as my first post i would like to thank you guys for teaching me so much, however i am new to the dodge world and there is so much to learn! i have read that the key trick will not work to check for codes on a 2001 24v. is this true?i do the key trick and i get "P done." the reason why i'm asking is my truck feels a little sluggish. i'm getting good fuel pressure 16-17 idle & 12 WOT. no hard starts, sometimes a little gear hunt once in a while but nothing major. just wondering about the APPS. my truck just hit 81,xxx miles and i am concerned about things that might possibly need maintenance. i got my fuel pressure under control and i'm running 2-cycle oil in my fuel (thanks to mopar1973man) so hopefully my VP stays happy, just worrying about other things. also where is the scan tool port? hopefully my buddy can scan it quick for me. anyways, aloha!
