jones154
  1. what is your guys experience with the air dogs or fass that have the air separator on them. are they worth it. do you notice any mileage improvements
  2. As long as we are on fuel systems does anyone know where I can get a fuel level sending unit without going into an in-tank fuel pump
  3. What all is everyone running for a lift pump
  4. When I parked the truck it was starting to gel up almost wouldn't run so I shut it off to avoid starving the system any more....in the mean time it's been hit with some extreamly cold negative temps and some warm...we had a week where it warmed up and the hired man took it to go get some supplies from a colony 2 miles away he said it ran a little rough at first but came around...it only ran maybe 15- 20 min after that it was hit again with -30 degree temps for a while and the last week it's been getting up around 15 to 20 degrees during day and around 0 at night I know it's running and not pumping which would cause it not to have pressure or flow to the injector pump unless the pickup was running which I never had ( is my thinking right there) What are some reasons for wanting to get an after market lift pump instead of OEM
  5. The fuel on the canister was liquid the old filter seemed like it may have had some fuel in it that was a little thick
  6. My trucks 100 percent stock. So the only fuel pressure gauge I have is connected to the bottem of the fuel filter housing on the way from the filter to the injector pump so if no fuel is flowing into the fuel filter there will be no pressure there
  7. So I haven't driven my my pickup in a month and a half and it was gelled up when I parked it but I put a bunch of treatment in it before I parked it and ran it for a bit and then parked it... Yesterday I put a new fuel filter in bumped the key to cycle lift pump to fill the fuel filter housing... When I did this I heard the lift pump running but no fuel was being pumped it was about 20 degrees yesterday.... The pump is only like 2 years old...has anyone had the pump run but not move fuel before or do you think it might just be gel in the lines
  8. I just went to move truck out of the shop for the week decided to drive it down the road and see what happens beings it's 9 out today....I drive a mile down the road pushing it hard doesn't do anything so I turned back around went the mile back and then another mile past my place the only thing it seemed to do was the same thing it does when it does the surge from the AC noise (just jumps up a couple 100 rpm) did that once one the way up and once on way back....not sure why it was so extreme yesterday but I'm thinking just AC noise from alternator or maybe the APPS...still will plan hooking a code reader to it tho
  9. Wouldn't spinning the tires throw the speed sensor code? I also know I have a diode out of the alternator could the junk diode that only acts up when I have my hid head lights and my PIAA fog lights on have caused it to do something like this when they weren't on.
  10. I'm kinda thinking and hoping it's gelled up -11 with hardly enough treatment for 0 probably wouldn't take long if there's any water in fuel - - - Updated - - - But after typing my last post I got to thinking with a little less hoping....if my truck was parked inside for around 36 hours at 45 degrees and part or the 36 hours it was 65 plus in the shop all fluids should have been around 45 plus degrees and even at -11 with moving fluids the odds of fuel gelling up in the ten min it was out side seems very unlikely to me so I believe I am back were I started so still clueless
  11. my 2001 has been parked in a 45 degree shop for the last day and a half. i started it let in run for a couple min. i then drove it out side where its -11 let it run for a few more min. i then babied it down the road for a mile the next mile i gave it a little more throttle about the time it was going to switch into over drive it when from 2100 RPM and dropped down to around idle RPM then jumped up to about 1800 RPM... I then turned around went back home. I got back to shop put it in park and held it at 3000 then went to 3500 RPM ran fine. i then pulled on to road and put it to the floor ran great power was all there then drops to 1000 and back up to 1500 or so take my foot off and catches back up... i pulled it into shop flipped key 3 times and the fallowing codes come up 1693, 1682, 0500. I dont have a code reader at the moment so i cant read all the codesIt acts like it might be gelling up or starving for air....I have diesel treat in it and even the ten min it was out side it shouldnt have gelled up.. i also pulled the air cleaner and it was pretty dang clean.... I also put a new fuel filter in it less the 600 miles ago... any help will be greatly appreciated thanks
  12. Was the AC noise that causes the surge a problem in the tranny a problem in the 98 12 valves as we'll
  13. Mine took about a 45 seconds and they didn't charge me a thing but had other dealers say anywhere from 35 to 70 bucks
  14. Not to turn this into an hid thread but a one thing to think of before buying hids is the 2nd gen only have one bulb which is nice when replacing bulbs however makes hids kind of risky if you live in an area where it snows or have a lot of fog I would maybe recommend not getting. If u live in such a place. hids turn a little snow storm into a complete white out same with dense fog I have had several times were I just turn my clearance lights on with piaa fog lights just to be able to see. The would be perfect if you could get them only for highs and just have good lighting on lows. A lot safer on oncoming drivers too.
  15. I have hids in my 01 I love them however the people I meet flashing there lights at me don't
