twin rocks
  1. I appreciate all of the quick replies. I called the parts store where i bought the filter and they suggested a shop close by that could do a fuel pressure test. They connected up to the hose at the isolator and read 20 psi at idle, while the gauge read 6 psi. So the problem is probably in the isolator. Nice guys, too, and they didn't charge me. A big load off my mind. Thank you again for all the prompt response.
  2. I'm thinking it could be the pump, too but idon't want to spend time and money on a fuel pumpI I don't need, like i did with the fuel filter. The gauge says "auto meter pro comp ultra lite must be used with isolator". Can't see a nodel numberThere is a rubber hose going into a red, fairly flat, cylinder (the isolator?), and from there into a braided stainless hose that goes into the dash. So, mechanical, i'm guessing?
  3. New member here. I had the lock/unlock issue. I rerouted the main ground wire away from the alternator. That worked for about 1000 miles, then on a rainy day the problem came back. While searching the net for other solutions I reccognized mopar1973man's logo from a post I read on another forum. His post at the beginning of this thread made a lot of sense to me, as I had thought for some time that alternator noise was the cause of the problem. So, I tried the test removing the 140 amp fuse, and the truck shifted normally. I bought a rebuilt alternator and had it installed. I have just completed a 3000+ trip towing a fifth wheel and there has been no issue. I sure there are several other causes for this problem, but the alternator was the cause for mine. I just wanted to thank mike nelson for this forum and this thread in particular.
  4. I have a 98 cummins 24v just turned 92000 miles, stock as far as i know. It sis come with 2 gauges, boost and fuel pressure, though itès only 15psi. It used to bury the needle just after startup. But recently, on a fifth wheel trip to the southeast, it started at about 9 psi and slowly rose to about 14 psi. It was shortly after a fiilup so i thought it might be bad fuel, so i added some diesel kleen in the white bottle and things seem to improve somewhat. I continued on to cold Canada, where i am cuurently at a friends place and the fifth wheel is sitting in a public parking lot (with permission, of course). Yesterday I started it up and it was at 6 psi, and rose slowly to 12. I changed the fuel filter, but it didn't help.This morning I had to move the truck and it was even lower at about 4 psi. The truck has run ok all along, no hard start, no white smoke, no loss of power. However, at about the same time the tailpipe began making a rattling noise at idle. Don't know if that's related or not. Does anyone have any ideas or suggestion? I'll appreciate any help i can get.
