Bradley Roufosse
Everything posted by Bradley Roufosse
  1. I have talked to the rebuilder about warranty. They said they needed the abs codes. I can't get the codes unless I take to the dealer and that isn't going to happen. I have another abs cab module I bought used from a 01 Durango to install while my original was out for repair(i installed just to keep my speedo going for my wife). It of course didn't get the abs working but it did keep the speedo going. Should I reinstall this and see if my ccd bus error returns?
  2. Hi everyone. Need some opinions on my ABS issue. Some history. The chip in my abs module went bad. Sent it to rebuilder in the states. Got it back installed and worked good for a month. Started getting random ccd bus errors. Disconnected abs module and all guages came back. I know the issue is abs related. Ohm test abs sensors all looks good. Is it possibly a bad soldier in the board? Any suggestions?
  3. Hi everyone. I just installed a Pureflow FRRP-100 on my 01 Dodge 2500. It works great so far. My question is my kit didn't come with a relay for the pump. The instructions say to plug it into the factory harness. I would like your opinion, should I install a relay or will it be ok?
