jphillips23
Everything posted by jphillips23
  1. Did swapping in the manual PCM clear the transmission codes and turn off your CEL, dealing with a transmission swap done by Previous owner and cant smog due to the CEL being on.
  2. P0753 and p1763. One is governor pressure sensor and the other is the trans 3-4 shift. which is due to the truck no longer having an automatic transmission, i think theres a trans temp code the scanguage isn't currently picking up as well. Not sure theres much to diagnose about the codes, as you cant fix that which isn't there. This is why I've come to the conclusion i should replace my PCM with automatic software for one from a manual.
  3. Little background on the situation. Bought a 1999 2500 that was originally an automatic converted to manual, truck runs fine, but is throwing codes for not having the auto tranny plugged in. Ive got the flash from smarty that converted the ECM to manual software but the truck is still throwing the same codes so it must be the PCM. Normally i would ignore the issue but i have to get the truck smogged (Commifornia) to complete the registration…. I know dodge no longer makes PCMs for these trucks so I figure a used working PCM is my best bet as I havent seen many great reviews from many websites selling remans. Will a PCM from a manual transmission truck solve my CEL issues, or will i experience difficulties due to the ECM and PCM not being programmed to the same VIN?
