DanKnoch
  1. Yeah, I will update. Been waiting to update to be sure things were resolved. So far, so good. Put the remanufactured ECM in this past Thursday evening and have not had any issues since. Knock on wood, I believe it to be fixed. I still cringe every time I turn the key and get really excited when it starts properly. Hopefully I can start to have more trust in the truck as the days go by. ECM fine print says needs to be installed by a certified technician so a buddy of mine stopped over to supervise so I could use his ASE number if there is ever a problem. Wish I would have tested some more stuff myself but as of early February we have a new baby so my time rightfully had to go to her and my wife and other 2 kids. So, I give credit to the first shop to look at it, just wish they would have sounded more confident in their diagnosis. Thank You all for your help and assistance with this issue, hopefully my headaches can help someone else down the road. Thank You all again, Dan
  2. Thanks, I have studied the wiring diagram. Lift pump runs for a short burst when the key is turned to 'run'. If I bump the starter, lift pump runs for 20 seconds or so. When the truck is having it's problems, try to start it, it fails to start, back the key from the start to run position, lift pump runs for a very short burst and stops. Seems the ECM is shutting everything it controls off. Heard I could cut the 'shut down' wire to the VP44 but I hate cutting things. Any idea how to pull the wire and connector terminal from the harness? Tried a hollow piece of brass tubing down around the outside of the terminal with no luck.
  3. OK, did some messing around and found when the truck stumbles while trying to start, that I am getting a voltage spike at pin 5 to the back of the VP44 harness. It spiked and went away faster than my meter could keep up, but I hit over 3 volts, probably more, meter reacts kinda slow. When I started cranking again, there was next to nothing in millivolts and it fired right up. I ordered the ECM I posted about earlier, didn't seem like too much to lose. Have good power to the VP44 harness whenever the key is in the run position. I heard I could cut the wire, but I don't really want to band-aid fix it. Is there an easy way to pull that wire from the harness to test run without it, I can't seem to find images of the loose connector terminals or the cummins tool to do it. Thanks, Dan
  4. Thank you for the info. I am not very good at reading those, but based on page 3, can I safely conclude that the fuel pump relay should have power to it whenever the ignition is on? I have worked on small engines that would turn off or not start as a safety if it read no oil pressure, I have good readings at the dash, could it be something like that? Also, 1 of the pins to the VP44 enegizes to turn off the engine. Is there any good place to probe for this with out pulling the harness? Tried checking the other evening and everything looked fine. Had a mechanic, friend of a friend, suggested the coolant temp sensor. Stated mixed readings may cause it to confuse the ECM and shut down. The gauge however reads good, unless for a split second at starting it goes nuts, hard to tell. Spoke to a computer remanufactuer, they said if I purchase an ECM from them and it does not correct the issue, they would refund the the money minus shipping and a $75 test fee. I am a little bit afraid to send the current ECM in for testing for fear of it falsely testing OK due to the inconsistancy of the problem. The past couple of cold starts have been without incident, has had problems after sitting for an hour or 2 and cooled down a bit. Thanks again for the help on this issue. Dan
  5. I am definitely with you on the ignition system, maybe not so much the switch as everything else stays on unaffected. Is there a good place to probe for power from the ignition to the ECM? Where does the wiring off the ignition split between the PCM and ECM or is that right at the switch? How would the block heater make this not be affected? And why only once per start? Coincidence??? Ignition circuitry inside the ECM perhaps? Thanks a ton for the help and suggestions. Dan
  6. What is the knock sensor rtn??? does it do anything Pin 33 on the ECM, pin 5 on the VP44. I am suspicious of this and will keep and eye on it.
  7. OK, got the truck back, not fixed. Truck sat in the drive for a few hours, had trouble starting. Unable to do too much since the kids are sleeping and the truck is quite loud. Clue: noticed that when I cranked the engine and it stumbled, I let up on the started but kept the ignition on. The lift pump stopped as is things were shut down. If I crank the started any other time and release it without starting it, the lift pump runs for a little while, 25 seconds I believe. Also, checked power at the VP44 harness and it was good, ignition on and cranking. Also, very little current through pin 5, the shut down pin, until I turned the ignition off, then 12v for 2 seconds. The schematic shows everything, ignition too, controlled by the ECM which also controls the lift pump. Any thoughts??? More testing to follow when I do not have to fear waking the kids and angering the wife. Thanks for the help, Dan
  8. Just an idea, Would it be possible that the issues are in the relay box??? Relay struggles to contact at 12v but works well at 14v when the truck is running. Could also explain the stalling which seems to only happen when the grid heaters drop the voltage down. The fuel pump relay would be the only one that could cause this since I don't have a security system to affect the ASD relay, right. I have replaced a couple of relays and moved some around with no cure.
  9. Thanks, I could not get the FSM to download. I downloaded the manual and the WinMD5. When I try to put them together, it tells me I have the wrong verification number. I may be doing it wrong, haven't had the best luck with computer stuff lately. Thanks
  10. Hi guys, Thanks for helping me out. No updates yet, going on Tuesday to pick the truck up. I thought and pondered the ignition thing for a little while, however, when it stalls, all the accessories stay on. I would think those would die, too. I am thinking when I get it back, maybe pulling the ECM and putting it in the freezer (am sure the wife will love that) and plugging the block heater in. In the past it has always started fine with the block heater plugged in. If it gives me trouble with a warm block and cold ECM, 100% the ECM. I am somewhat afraid sending the ECM out for testing won't be conclusive since the problem is intermittent and temperature related, any suggestions. Mopar1973Man, you mentioned Klein-Bottle computer when I spoke with you on the telephone, I have read mixed reviews on them, do you have any personal experience with them? I know not to believe everything I read online. Thanks again, Dan
  11. Hello, I am new to this forum. I spoke to Mopar1973Man on the telephone, Thanks to him for sharing his wealth of knowledge. Here is the info I provided to the service facility: "Vehicle information: 2002 Dodge Ram 2500, 5.9 Cummins HO, 6 speed manual, 4x4. Modifications: Injectors-Formula 1 Mach 2 105hp, Smarty S-03 programmer, FASS. Symptoms: For the past 2 months, truck has had issues starting ranging from a hard start to stalling nearly a minute after being started. This all seems to take place when the temperature is below the operating temperature of 190. If I make several stops before the truck is at running temp, it usually has trouble every start. It has not failed to start, just takes longer, and when it has stalled, it has restarted on the first revolution. When it is trying to start but is having problems, if I back the key from the start position and try again, it starts instantly. Often, to put it simply, engine will crank-crank-try to start-crank x3 and start and run great. What I have tried: Found a bad relay for the grid heater, replaced the grid heater relay (only code this whole time). Replaced the Cam position sensor below the VP44. Took the truck to a local shop who stated they “think” it is the computer but they could not find anything wrong and they didn’t sound convincing enough for me to drop $1000 on an ECM because they “think” that is it. Tried starting the truck with the lift pump relay pulled so there was no initial fuel pressure-no change. Per a conversation with Doug of Blue Chips Diesel, I put a heat gun to the VP44 for about 10 minutes one morning and it started and idled good with no symptoms. Not enough to convince me since sometimes it will start and run without incident. However at that temp, I went about 10 mornings in a row with starting problems, only started good with the heating. Initially, the symptoms seemed worse with the Smarty programming, after trying different things and stock software, problem was still present. At this time, I suspect either the ECM or the VP44 but since you guys are the pros, I leave it to you. Call if you have any questions. VP44 is the 3rd one, about 9 years old with 110,000 miles. ECM was replaced about 5 years ago with a rebuild. Thanks You, Dan Knoch" Also, the truck will only have these symptoms one per start. Once running, it runs fine. If it starts without an issue and drives 300 yards without an issue, it will be fine until the next time I try to start it. A second Service facility had the truck for 3 weeks, replaced the VP44 without resolving the problem. Mopar1973Man advised to test the Alternator for AC voltage and have the ECM tested. I will advise what I find. Thanks, Dan
