Botlebruiser
Everything posted by Botlebruiser
  1. Ok, so I bought this truck a few months ago. It was about 4 hours away so I had it shipped home after I went and looked at it. I got a great deal on it. The transmission was completely gone so I ordered a Firepunk Street/Strip trans. It also ended up having a burnt valve which was unexpected. After comparing pricing with machine work and/or just purchasing a new a head I went with a new loaded head from Promaxx. I swapped out the stock valve springs for Hamilton 103lb vavle springs and used ARP Head studs in place of the factory head bolts. Everything is good there. So now after the transmission, head, starter and wheel bearing were all replaced I'm having an issue with engine error codes. I've got them listed below. I doubt all of these are actually bad but I definetly have an issue to address and probably a sensor or two to replace. Any ideas guys? Codes P0336 - Crankshaft Position Sensor signal P0237 - MAP Sensor voltage too low P0122 - APPS Sensor Signal voltage too low P0118 - Engine Coolant Temperature Sensor voltage too high P0113 - Intake Air Temperature Sensor voltage too high P0382 - Intake Air Heater Relay #2 control circuit
