Hocutt27
  1. I installed the timbo sensor a little over a month ago and it seemed to have worked fine for about a month then the bucking and dead pedal started again this time not as bad but still could tell it was the same problem. So I cleaned all battery cables then reset it and it worked for about another week and now is doing it again. Could the sensor I got be bad? What am I doing wrong?
  2. My low beam on the passenger side is not working but works when you turn on high beam. Is this from a short in line somewhere or switch or what? Has anyone else had this kind of problem. I have changed the sockets out with new ones, checked for shorts (as good as I can while on the truck) on the harness but nothing to obvious. let me know what y'all think
  3. I have been experiencing dead pedal some times it is as soon as I take off other times I can drive for 30 min before any bucking happens. I have already replaced the APPS with a new one and it worked fine for about a week or more then it started again. What could be the cause of this to make the sensor keep going out?
