Hockeyfm13
  1. Howdy folks! I'm currently working on replacing my exhaust system with a Diamond Eye 5" inch kit and have come across an issue. My old down pipe has corroded itself to the the exhaust flange waste gate elbow (Part #3590110).. so I need a new one, but I can't find anything online. Can someone help point me in the right direction? Should I use one from a different turbo setup?
  2. Is there a 200 degree thermostat that I can put in my 2001 24 Valve? Can you post the link to one, or a part number? The region I'm in sees temps averaging between -15 to 0 degrees Fahrenheit. Opinions are always welcome!
  3. What do you recommend for LED's and headlight housings? Is there a light/housing combo that you would recommend? I need something that is very bright both short distance and long distance as I do a lot of traveling during the night hours.. Also, they need to perform great during snowy and rainy conditions. Links to products would be preferred. And no, I'm not a fan of light bars. Let's hear those setups/recommendations! (Please include any necessary wiring harnesses for setups)
  4. Hey, @Mopar1973Man , Are we running any cyber Monday deals on your high idle switch? ?
  5. In search of new bulbs and headlight assemblies. What are the best combo packs for those dark nights? And winter nights.. LED'S or HID's? Preferably something that isn't going to cost a fortune. Amazon works the best. Drop web links, please.
  6. Mega hill, roughly 55. I'd still like to see what people run for extra or aftermarket coolers.
  7. Yes, everything stock-related works as it should.
  8. Yes.. You are correct, the 2nd gen mirrors don't come with the blinker light in the connectors. I already know how to wire those though.
  9. What brand or website should I order full power-heated tow mirrors with blinker lights? Or can I mount on some 4th gen tow mirrors? (2001 Ram 2500)
  10. Wondering what I can do to help lower transmission temps drastically. The other day I ran a little over 200 degrees pulling a 7 thousand pound trailer. (Built tranny with triple-disk TC, shift kit, and heavy duty bands.) Do you guys recommend transmission coolers/fans? Drop some links in the comments of products that you have or have opinions on. Thanks a bunch! Also, have you guys read about the new Smarty MM3 tuning for 98.5-02's?!?
  11. Alright guys. Just tried everything and still won't come off. I tried using the power steering method. And I even put the rotor on backwards and hit it with sledge hammer... Any other thoughts?
  12. Spicer grease able joints or grease free?
  13. I'm currently in the project of replacing u-joints and bearings on the front axles. How do I get the bearing housing off? (Of course I have already taken the four bolts out.. And the axle nut.) I have taken a solid hammer to it, including a chisel and 5 pound hammer. Any tips or tricks that you guys would recommend? Thanks in advance!
  14. Can someone post a link to the product?
