WYOMING5.9ISB
  1. How much did it cost to get the crossover tube seals replaced. I see that theres oring on the tubes themselves bur I also see that theres a seal in the head themselves where ir connects to the injector.
  2. How much did it cost to do return lines?
  3. So now I'm selling fuel in my blowby...
  4. I called everyone around my area. No one has it. I'm just going to send then in to DAP and have them do a pop test and if bad have then rebuilt.
  5. Yeah I hope your dash is already broke. Because it will be broke by the time your done.
  6. I called everyone around my area. No one has it. I'm just going to send then in to DAP and have them do a pop test and if bad have then rebuilt.
  7. I pulled my injectors. And there fine. They all have the tips.
  8. Okay. I got all the injectors out and everything looks clean. I called Diesel Auto Power and its $110 for a rebuild
  9. I'm pretty sure these injectors can't piss. The vp44 dosent work like that common rail if I'm right???
  10. Thanks sir. I will give it a try and get back to you later
  11. I do have to say. Smelling It.. It smells a little funny... Not like raw diesel.. Or even oil... It just has me and all my friends mind bobbled.. Have u ever heard of the valve stem seals going bad in these trucks? This is a picture of accelerating lightly.
  12. This just started happening a week ago. And overhead mpg. Smoke stays same with temps. And I drive 15/30 miles ever time it is started. And egts haven't changed
  13. I typically get 18/20 and it hasn't changed at all
