WYOMING5.9ISB
Everything posted by WYOMING5.9ISB
  1. How much did it cost to get the crossover tube seals replaced. I see that theres oring on the tubes themselves bur I also see that theres a seal in the head themselves where ir connects to the injector.
  2. How much did it cost to do return lines?
  3. So now I'm selling fuel in my blowby...
  4. I called everyone around my area. No one has it. I'm just going to send then in to DAP and have them do a pop test and if bad have then rebuilt.
  5. Yeah I hope your dash is already broke. Because it will be broke by the time your done.
  6. I called everyone around my area. No one has it. I'm just going to send then in to DAP and have them do a pop test and if bad have then rebuilt.
  7. I pulled my injectors. And there fine. They all have the tips.
  8. Okay. I got all the injectors out and everything looks clean. I called Diesel Auto Power and its $110 for a rebuild
  9. I'm pretty sure these injectors can't piss. The vp44 dosent work like that common rail if I'm right???
  10. Thanks sir. I will give it a try and get back to you later
  11. I do have to say. Smelling It.. It smells a little funny... Not like raw diesel.. Or even oil... It just has me and all my friends mind bobbled.. Have u ever heard of the valve stem seals going bad in these trucks? This is a picture of accelerating lightly.
  12. This just started happening a week ago. And overhead mpg. Smoke stays same with temps. And I drive 15/30 miles ever time it is started. And egts haven't changed
  13. I typically get 18/20 and it hasn't changed at all
  14. Woulnt that cause loss of power/bad gas miliage?
  15. No codes... And when its idling the exhaust smells a little funny but not like oil tho.. And it's a hase when I accelerate slowley and when I let out at about 60mph it really thick.. This picture isbwhen I let out at 60mph. And it will smoke like that only when coasting... When I barly put a little pressure of the throttle it goes away..
  16. Join Date: Dec 2015 Location: Wyoming Posts: 5 Thanks: 1 Thanked 0 Times in 0 Posts iTrader Score: 0 reviews WYOMING5.9ISB's Truck Pics White/Bluish Smoke Problems help.... I have a 2000 Dodge 2500 With 160k I recently am having problems with it smoking on a light acceleration until about 30mph. It stops smoking until I let of the throttle at about 60mph. then the smoke just dumps outta the pipe. I tried a hard accretion and no white smoke what so ever. Even when I let out of the throttle no white smoke at all. I am not noticing my coolant level or oil lever changing at all either. The Mods I have are Smartys03 stacked with an edge comp box. airdog lift pump. 125D62/80 silerbullet.
