mowfast64
  1. You are saying the band strut is bad so it won't shift out of 1st. gear. Mine will shift if you let off the throttle.
  2. No codes I'll check the spring tomorrow. The fluid level was down one qt. I didn't want to put any in till I figure out what I'm going to do with it.
  3. 2001 dodge ram I changed the TV but it didn.t help. It won't shift out of 1st. unless you feather the throttle.
  4. Won't shift out of 1st. gear. You can feather the throttle pedal than it might shift. I need help! I don't want to just start changing parts.
