DBW
Everything posted by DBW
  1. 02 dodge diesel, had alternator bench tested it showed that it passed. Battery volts 14.69 ripple volts .39 did it really pass noise level.
  2. Thank you , for the info. and fixing my truck
  3. Thank you i will try that. Dynamic, that work. now what, do i leave the jump wire?
  4. yes, I can manually shift to 2nd that it.
  5. Hi, I'm new to this site. Have a question about a transmission issue: Started almost one year ago, while pulling my 5th wheel RV. Had driven about 15 miles and it went into limp mode. Took to a transmission repair shop the following day and they replaced all the solenoids in the transmission. Problem continued, so took truck back to repair shop where they said it had thrown a code for the 3rd and 4th shifting solenoid (malfunctioned). They then replaced that. Problem still persisted. Repair shop then said it needed a new 'brain' or PCM. Took it to a Dodge dealer who replaced this part. Still having problems. Here is what is occurring: When it first started acting up, upon starting first thing in a.m., starts in limp mode. This would continue for approximately a mile. Then I would shut it down, wait 5 minutes and restart it. That would solve the problem unless the truck sat for 2-3 hours. Then upon restarting it, it would again start in limp mode. Now, the time it stays in limp mode after the initial start up is getting longer. Sometimes when I shut it down and restart it, it will only work in 1st, 2nd, and 3rd, but won't shift into 4th and overdrive. If that happens, I will drive another mile or so and restart it again and it will be fine. Other times, once I restart it, it shifts into all gears. I have consulted with many different people and forums and it seems no one has had this particular issue. Many think it could be a wiring issue, but I'm not sure if that's it. I'm wondering if it could be a pressure issue? HELP!!!
