01cummins6
Everything posted by 01cummins6
  1. Would unhooking it hurt anything if it's bad
  2. I have a 01 cummins was in a hurry this morning went to pass Someone and covered the road in smoke. Truck is bone stock straight piped.
  3. Anyone know what tools and the procedure
  4. Anyone have a right up on how to replace upper and lower ball joints on a 2001 dodge ram 3500 2wd
  5. Has anyone ever done the stock airbox mod
  6. I didn't see anything scored and everything else is fine. But there was 4 different seals and I'm not sure it's the right one it fit but it is leaking around the yoke
  7. I checked it last night it's fine
  8. I need help locating a pinion seal for my truck .it's a 2001 dodge ram 3500 2wd 6 speed with a Spicer yoke. I replaced it and is still leaking.
  9. Ok didn't know if I'd have to pull the tray out or not
  10. What's the easiest way to get to the old plug ?
  11. Anyone know what size the hood nuts and grill insert bolts are for a 07 dodge ram 3500
  12. Where can you get a plug and how hard to change
  13. Passenger side headlight will go off until I wiggle the plug wire truck is a 01 6speed? Then comes back on
  14. Is Prestone coolant flush any good?
  15. What's the best coolant
  16. Been awhile no over heating and heats fine
  17. My radiator cap has green sludge around it. Any ideas? Oil is normal
  18. I just need a new filter and yea that's a 10 inch long filter.
  19. This is my set up filter is s@b
  20. Truck is stock so just something reliable I've had oiled filters never cared for em
  21. Ok just checking who makes the best non oiled filter?
  22. So a filter with a 6 inch inner diameter is what I need
  23. What does the inner diameter of my air filter need to be to go on a 5 inch intake pipe?
