01cummins6
Everything posted by 01cummins6
  1. Yea mine hasn't yet but gonna try any tackle it this weekend
  2. Mine looks to be leaking at the front passenger corner of block
  3. The circled area is the leak right above is where the head aND block come together. Did you have any coolant mixing with or anything
  4. It'll be after I get off work
  5. In that location could it also be thermostat housing leaking
  6. Leak coming from front passenger corner of block. Quit for awhile then started again. No coolant in oil
  7. Where can I get shorter blocks
  8. The truck has overloads in the rear is the reason im leveling it .it also looks like you have to take out the ball joints to do it on a 2wd.
  9. How do you install a 2 inch leveling kit on a 2001 dodge ram 3500 2wd
  10. Where can you get new u bolts
  11. I have a 2001 dodge ram 3500 2wd. What's the best way to lower the rear?
  12. On the 2001 3500 I think the rear hub bolts to the rotor
  13. I'm asking what tools and if I need to replace the nylon nut.
  14. Needing help on what I need to change rotors on my 2001 3500 2wd
