Thatguy
  1. What does time = when your getting paid to do it? Edge wants 150 plus shipping for a new one.I'll post back if it works
  2. I guess I don't see the issue, edge told me the modules are identical for 98.5 through 02. The harness is the only thing different. Both sensors use 5v supply. as long as I use the 01 map on my 01 truck it should be happy? I just need to figure the wiring out. Thanks for the help
  3. So after looking at the prints there both 5v supply, the wire orientation is different but I can fix that. Mopar man are you saying the edge module itself won't work? If worse comes to worse I can just leave enough pig tail on the round male connector to resplice it if it doesn't work.
  4. I called edge, they just said I need a new harness
  5. So I lucked out on a edge juice cts, but it came with the wrong map plug. My truck is the 01 and it has the plug for the 99. From what I've been able to find on the Internet is that there different voltages. One being 1.0 and the other being .5, I was wondering if I could just use a resistor to drop the voltage or if there's more to it than that. I'm assuming the map sensor output to the computer is millivolts?
  6. No I did not. Just check gauges from the low voltage
  7. its definitely came a long ways. I think i'll start visiting here more often compared to the others. Better informative information here
  8. Alternator Starter and Parts wholesale. I called to order,there out of florida. The guy even sounded like an American! dam I didn't even know you had a store mike,well my 2wd is reading a little high in AC noise so when I order another itll be through here
  9. ordered new rectifier/diode and brushes for 43 bucks shipped. slip rings look good and bearings feel good so I'm going to leave it at that
  10. Well with my truck running at 8.8-9v when I got home I decided it was best to shut it off and put the battery charger on it. Pulled the alternator off and tested the diode pack. 4 smoked diodes.
  11. So do you have any idea if 40ohms means charge or not charge from the PCM?
  12. Because the alternator only charges when it's told to, via the computer. If the voltage regulator/computer doesn't send the output to the alternator to charge, it won't charge. I just wasn't sure if 40ohms to ground was a good enough ground. Still waiting on me78569 to clear that up
  13. So what exactly does that mean?
  14. So I get the low battery light otw home, barely make it home with my edge reading 9v. I pull the 2 pin plug on the back of the alternator to check to see if the computer is calling for the alternator to charge. On the hot wire I got 9v,the ground wire I get 40 ohms . Isn't 40 ohms to high for the ground? I figured it should read a lot lower, didn't know if that was why my alternator isn't charging or not.
  15. Thanks for help guys I appreciate it
