Dieseltech29
Everything posted by Dieseltech29
  1. when I tried to update manually it says that driver is already updated. I browsed for driver and used the bin folder location for it and it said its already the most updated driver. it does constantly connect and disconnect when pluged in to usb port. I will try home computer. just trying to get set up for when iquad module shows up later this week
  2. just so I'm clear this is the file I need to load to update to v2 so that I can run the iquad correct? I think my pc at home is A 64 BIT machine if it comes down
  3. I am having this same problem below as well. does anyone have any information??? Posted April 13 (edited) · Report post I have followed this several times without any success. When I run Step 2 it goes through all the process and then gives me an error code that says the software is not compatible with my version of windows and to contact system publisher to make sure getting the right version of software for 32 bit or 64 bit windows. Running windows 7 Pro at 32 bit. I have followed the instructions and had to manually install the driver. Trying to update a XZT+ and was referenced to this information by the Tech Support at Quadzilla. Any help would be great as I do not even know what tune is loaded onto this box as I just got it used. Also when trying to launch out of the downloaded tune file I get a different error message. Attached that as well. The box connects and then after a few seconds it will disconnect and then reconnect constantly every few seconds cycling. Thank you.
