weaselguys
Everything posted by weaselguys
  1. Dropped the truck at the shop this morning it whines in first and second now loudly, they drained part of the fluid it was full of metal shavings, so time to get a rebuilt trans and I was thinking of upgrading to a South Bend or Valair 13" clutch, I do tow a lot at the 13,000 lb weight and was figuring on pushing the horsepower up closer to 400 hp.
  2. I just came back from a camping trip and when I was 60 miles from home towing my 30 ft fifth wheel and 12' flat bed trailer with a side X side on it, I stopped for fuel and when I pulled out of the pump I could hear a noise under the truck so I stopped and the noise quit soon after kinda sounded like exhaust spit to me. When I got back on the highway and got back up to speed everything was fine till I went for 5th and it just ground I backed off and slowed down then got back up to speed and same thing it ground in 5th. I had one shop familiar with the fifth gear nut problem say they usually make not noise at all. Does this sound like a fifth gear nut issue or worse. And for those that have had the nut issue has anyone tried one of these to help keep the nut on. https://puredieselpower.com/dodge-products/dodge-4wd-nv4500-transmission-5th-gear-repair-solution.html
  3. Mopar1973man can you explain this to me is it just holding the waste gate closed or open to get more boost and do you think it is a good idea or not ?
  4. This is my currant tune. File Name: XZT+_1008 Models: DXZ29802 Software Version: 20080128 Feature Code Enabled: XZT+1008 Features: • Factory Tuning file that all XZT+ Modules are shipped with • Adds Automatic 1200 RPM High Idle • Hi Idle not for use with Factory High Idle • Adds Cold Engine Protection set at 170 deg Coolant Temperature • High Idle will engage any time the vehicles is in warm up after 2 minutes of continuous idle regardless of switch position • High Idle will only engage in the OFF setting once engine has reached 170 deg Coolant Temperature • Module will default to the OFF setting regardless of switch position when Cold Engine Protection is enabled • 1 Minute wait period before High Idle engages • High Idle may be disabled by touching the accelerator pedal or by changing switch positions • 2002 Trucks May also kill high idle with the brake pedal • High Idle will engage regardless of temperature but my high idle engages at a lower temp for some reason , I may change to this one File Name: XZT+_1009 Models: DXZ29802 Software Version: 20080128 Feature Code Enabled: XZT+1009 Features: • Factory Tuning file that all XZT+ Modules are shipped with • Adds Automatic 1200 RPM High Idle • Hi Idle not for use with Factory High Idle • Toggle switch must be in the OFF position in order for High Idle to work • 30 Second wait period before High Idle engages • High Idle may be disabled by touching the accelerator pedal or by changing switch positions • 2002 Trucks May also kill high idle with the brake pedal • High Idle will engage regardless of temperature or try a more aggressive one File Name: XZT+_2006 Models: DXZ29802 Software Version: 20080128 Feature Code Enabled: XZT+2006 Features: • Same Aggressive Tuning File as XZT+2000 • Adds Automatic 1200 RPM High Idle • Hi Idle not for use with Factory High Idle • Toggle switch must be in the OFF position in order for High Idle to work • 1 Minute wait period before High Idle engages • High Idle may be disabled by touching the accelerator pedal or by changing switch positions • 2002 Trucks May also kill high idle with the brake pedal • High Idle will engage regardless of temperature If I switch tunes I will only use the stock or off setting for start ups.
  5. I may change the tune to one without the high idle , it is nice at start up but I dont like it coming on when setting in traffic anyway.
  6. I have a 1999 2500 with manual trans and I added a Quadzilla XZT with a tune that has a high idle on it .I was coming home from work one afternoon and turned off the highway onto a residential street and my rear tires hit a icy patch and started to spin , the rpm's came up and it felt like the high idle kicked in and the truck tried to take off on me , so I pushed in the clutch to stop it and the truck just shut down. I coasted it onto another street and stopped and tried to restart and it wouldn't so I let it set for a few minutes and then it fired right back up . Is there a rev limiter that can shut the truck down or a relay that can trip causing it to not restart and should I do away with the tune on the XZT with the high idle ?
  7. Ok I installed my XZT+ today I was not sure about the data link plug in the XZT would not plug in far enough for it to latch in place so I had to tape it , here is a pic of the plug I used . The XZT I ordered had the following tune. File Name: XZT+_1008 Models: DXZ29802 Software Version: 20080128 Feature Code Enabled: XZT+1008 Features: • Factory Tuning file that all XZT+ Modules are shipped with • Adds Automatic 1200 RPM High Idle • Hi Idle not for use with Factory High Idle • Adds Cold Engine Protection set at 170 deg Coolant Temperature • High Idle will engage any time the vehicles is in warm up after 2 minutes of continuous idle regardless of switch position • High Idle will only engage in the OFF setting once engine has reached 170 deg Coolant Temperature • Module will default to the OFF setting regardless of switch position when Cold Engine Protection is enabled • 1 Minute wait period before High Idle engages • High Idle may be disabled by touching the accelerator pedal or by changing switch positions • 2002 Trucks May also kill high idle with the brake pedal • High Idle will engage regardless of temperature and the box was marked stock 35HP 70HP I took it for a test drive it does work , only a high idle in the 70HP setting , it had a slight HP increase in the second setting but had smoother acceleration and the 70HP setting was much better with nice acceration going up hills and my MPG guage showed no decrease but a .1 mpg increase over the test drive. I think it will help nicely pulling hills with our trailer.
  8. Ok I ordered the quadzilla XZT and now I'm looking at a fuel pressure gauge I'm thinking a ISSPRO electrical 40psi unit , I know mechanical is best but also harder to hook up. I already have a double pillar pod and will have to put the fuel psi gauge elsewhere. I saw on the cummins forum that mopar1973man had a article on fuel gauges but could find it.
  9. Me78599 thank you for the info , Quadzilla it is. I see the tunes are avalible for donating members only where do you donate and how much does it require ?
  10. Me78569 is the a cable to do the flashing myself that I need to order when I order the chip and I am guessing it will probably require a computer with win vista or 7 and up right ?
  11. Yes you can have the tune changed if it doesn't work out , but you have to take it off and send it back to them, bummer.
  12. I have run my truck for a little while now and it needs help when pulling the hills with my trailer a 6% hill with a straight shot it will pull well if I push it hard at the bottom but curvy roads with slow corners and I end up staying in 3rd not enough power to go to 4th. I am looking at a edge EZ and a Quadzilla XZT right now , the cost is good and they are basically plug & pray no messing with tuning I'm just not that up on diesels yet. For the XZT I was thinking the XZT+1008 tune or XZT+1011 for the high idle in cold weather and then I will add a BHAF and 50hp injectors if needed . Which chip would you suggest ?
  13. Does anyone know of a set of airbags that will work on a 99 2500 4wd that mount over the axle not the leaf springs (so I can keep my over loads) and they need to work with a goose neck or fifth wheel mount.
  14. Dieselfuture I found the tag in my glove compartment showing my gearing as 3:55 so I put on 265/70r16 tires , according to my mgh gauge I am only getting 15.8 mpg and with the speedo showing 60mph with the currant tire at between 1900-2000 rpms ,I wish I had gone to larger tires. I am installing a Ultra guage soon and see what it has to say, I cannot decide on air filtration yet , I do run a k&N and a Outersware prefilter on my jeep and I trust it , but I understand the possibility of dust and oil getting into the turbo so I wont do it on the cummins beoynd that I may try the BHAF wit a prefilter but water splash is a concern for me as I know I will make creek crossings in this truck.
  15. Ok quadzilla first then , I would have responded sooner guys but yesterday the reply window wasn't coming up for me no matter what I did. I was just quoted $1361 for a exhaust brake but he didn't say what type or if it included install I may do that first and then the quadzilla .
  16. Finally got my truck today and off to get tires in the am getting 265"s since it feels pretty low geared, I saw today it has a Fass DDRP on it found a new bug screen and winter front under the back seat . So should I add the exhaust elbow first or the quadzilla ?
  17. Can you use a exhaust brake with the exhaust elbow ? Xtremdiesel power has the Quadzilla ADR 1000 Adenaline with control pod for $594.99 and the iQuad module is $194.99 if it is needed , a Scan Guage II may work as a monitor I not sure.
  18. Hi newbie here I am just getting my first diesel pickup a 1999 Dodge 2500 SLT 5 spd which I will mostly use for towing a fifth wheel and would like to up the HP .Towing will include steep hills 5-10% grades 3500-9500 ft . I was thinking about better intake air flow and 4" exhaust and a exhaust brake . I see Van Aaken , Quadzilla XZT , smarty and Edge EZ listed most for chips/programmers . Can I just and a programmer for the extra 30-50 hp or do I have to add a exhaust elbow too . I have a Bully Dog boost gauge already and a EGT gauge that is not hooked up yet and was thinking of adding a fuel pressure gauge also.
