Matthewski89
Everything posted by Matthewski89
  1. I have a 4k v2 box. The box is 6 months old, i had a problem with it begining of this month. My truck wouldnt start and all my lights on dash stayed on no matter what. After days, i found out there was a short in the box. Took it off sent to quadzilla, the replaced the board. Sent it back and now having this problem. Im wondering if when they replaced the board if they didnt replace it with the v2? Im really not sure
  2. Okay i did that, and i also went in and counted and it does have 45 of them and nothing has changed everything is still the same as its always been. I tried to upload the tune. Also ive noticed in the ez tune builder the maximum pump stretch range im getting is like from 1200-1800. The parameters in the app on mine is 4000-6000? iQuad-test-2017-12-19-10.43.021395022030.json
  3. Mine is for sure not working. This was after 10 minutes. Might try to get a hold of quadzilla today. If i go to default settings it will load in a few seconds. Soon as i try to load a custom tune it just wont.
  4. Cool i downloaded it, will give it a try in a little while hope its better
  5. Okay, i will try to give it a little while longer before i try to change pwr levels see how that works out. Im on android as well
  6. Finally figured it out. It wouldnt download correctly from yahoo mail. But it works when i use gmail. Now that thats figured out i cant grt the app to connect and when it does and i try to go up the power levels it freezes. Anyone else having same problem?
  7. I do not have a downloads program, just what the phone came with, i did try to email it also and open from there and this is whats displayed now. Wont let me open with iquad.
  8. Yeah, there is no update available so it must be the most current one out. Im going to apps. Going to tools, then my files, then downloads. Samsung galaxy8 plus
  9. Just tried that and getting same message. I cant immagine the app needs to be connected to the truck at the same time right? Maybe its just my pos phone?
  10. Everytime i go into my file downloads and try to open a tune file i exported OR downloaded it gives me this error. I tried uninstalling the app and reinstalled and same thing. Anyone have same problem?
  11. no, i dont have any defueling for egt or boost
  12. Thanks, I will give that a shot. That 88 loves the fuel when it's spooled! Will have to test out your changes Wednesday I blew a 7ply boot apart today at 80lbs time for some more v bands
  13. been doing a ton of reading and trial and error and having slight difficulties with my tune. i have a 99 cummins with a built 47re, fass 150 6x.018 sac injectors .093 tubes, stock lines, dragon flow 150% over pump. arp studs, 103# valve springs and extreme duty pushrods, and 67 / 88 compounds. ive got a good DD tune that has very minimal smoke, working on my track tune and on level 5 it will rev all the way to 4k when i put it to level 6 with 100% wiretap it cuts out at 22-2500 rpm sounds like its hitting limiter not sure what to change to make it pull all the way to 4k without cutting out like that any info would be appreciated
