juspassinthrough
Everything posted by juspassinthrough
  1. Hello got a 2x4 03 truck that has 4x4 light comes on in dash and has 3 codes which involve 4x4 in computer that my smarty won't erase any thoughts.
  2. OK guys got 2003 2x4 truck has p-0839 p-0838- p-0837 codes with are voltage releaded for 4x4 truck why is this on a two wheel drive thanks.
  3. Ok guys my 05 had vibration at idle give a little fuel would go away so search forums i looked and thought about problem took to a shop they keep it a week no luck on problem so went to pick up truck paid bill .Went to leave in truck turn key on adjusted my edge attitude to stalk it was on 3 started truck guess what vibration was gone it shook cab mirrors seat terrible.( So the edge was problem its been on truck since brand new with 170,000 miles now .its been good but time to buy new programmer looking for recommendations i tow 16k rv not in to crazy power I'm not a computer whiz i use a mac lap top so i no on this site smartys are hot but just how user friendly are they and which one would i need still have edge in truck need advise . thanks
  4. Hello thanks i run a edge juice no hot rod just pull a rv i just want something reliable i could buy new but like to have my trans rebuilt and upgrade both so if bbi rebuilt would run then that would be fine i assume you no others running the rebuilt bbi with out issues thanks.
  5. Hello again so how are bbi rebuilt injectors will they work or just buy brand new ones thanks. by the way im just looking at pre maintance trucks runs starts good got 17000 miles on it 4 original injectors one when it had 30 thousand on it one at a hundred should i just add a 2 micron filter drive it or change them same about the trans we travel const so been thinking about the warranty on trans talk to amscott transmission there 4000 but they have shops world wide so what's your opinion thanks.
  6. ok guys are injector direct injectors any good for a 05 they advertise oem bosh injectors for 1999 dollars are they good or junk thanks
  7. O k fellows i have a 2005 170.000 miles transmission works fine but thinking of pre maintance we travel construction i pull 16.000 lb rv worry about breaking down on the road i no there several places to get a trans but I'm concerned about a warranty . also thought about upgrade vb and tc and drive it or just drive it. So if a person does what i do to make a living thoughts on best thing to do with it i drive the truck little bit but pull rv couple times a year located now in raleigh nc
  8. 2005 dodge ram 3500 vibrates at idle seems if you put in gear gets better has 1.70000 on it one owner runs great good fuel mileage edge tuner on it since new this vibration you can feel in the seat also any ideas,, ALSO trans has never been messed with except flush fluids clean not burned i was wondering if i change tore converter and maybe updated valve body might head of a problem i tow a 16 thousand pound rv around the country. IDEAL ALSO THANKS
  9. moparman don't no axel ratio but at 65mph I'm turning 1800 and have 265-75-16 tires
  10. ok guys my 2002 fuel mileage sucks iv had different issues with it had a miss at idle changed injectors fixed miss put dap 50hp in it got a edge ez tuner fass pump boost gauge about 10 on it when getting in it and about 4-5 driving 55 fuel pressure 20lb idle 16 down highway iv checked fuel mileage in town about 13 mph . so could tuner or injector cause bad fuel mileage i mean shouldn't it get a little better i drive like a old man thanks.
  11. OK guys when checking for boost leak do i plug off air horn when i pump it up to 20lbs it don't hold very long i bought tester looked at tube didn't find no good info but installed boost gauge it makes 20 when mashing skinny pedal down 4lb at 50 and holds it 6-8 at 70 holds it could i still have leak its a automatic thanks
  12. treed how is borg warner s366sxe and would it work on this 02 sorry don't no much about turbos thanks.
  13. no i don't but do you no any thing about cordone turbos thanks
  14. ok fellows pulled hose of my turbo check it no in and out slack but up and down seems 1-4 inch found a garret 54 trim 0.60 turbo used for 300 bucks will it work on this 5.9 with 4 inch exhaust and 50hp injectors ez chip fass pump no nothing about turbos if not wheres ben place to buy one or info thanks.
  15. Hello it smokes a little at start runs good i have 4 inch straight exhaust edge ez sump in tank fass pump 1-2 inch lines new 50hp injectors run overhead going to install bhaf tomorrow had a fram in it i no stupid ill check for boost leaks i notice bottom of turbo had oil on it i can't here turbo when running truck. Also this is stupid also order fuel filter from genos garage would not fit when you put filter in cap won't screw down had a 99 ram same way finally ordered a updated filter housing no more problems like someone changed caps this 02 is same way my brother has a 01 filter for his would not fit he had a extra so i got a filter from international dealer it worked but was shorter any ideas sorry for long message but don't understand both trucks had same issue with filters oh trucks idels 20 lb 15 down the road thanks for info ill let you no on boost.
  16. fuel pressure 20 at idle 15 down highway at 70
  17. after changing injectors before got 18 thanks
  18. update changed injectors miss gone put 50 hp injectors in fuel mileage 14mpg not real happy with that but life goes on.
  19. Hello will it hurt to delete air box just put air filter on inner fender. also opinions on spectre air filters with pre filter thanks.
  20. Ok guys i have a 05 3500 bought new with 135000 miles on it i use truck to pull 16000lb fifth wheel travel const not a daily driver trans works fine but was wondering about updating torque converter for pre maintenance don't want it to fail on the road though maybe i could head off a problem thanks for thoughts. Sorry i have 2002 also.
  21. Where did you buy parts for the bosch if you don't mind telling me thanks,
  22. Ok guys still chasing my intermediate miss still may be injectors but want to ruel out alternator first ac noise mine is 0.24 has bosh on it bought rebuilt at napa it was worse so one would alternator cause miss and is 0.24 bad and will dens0 alternator fit my truck in place of bosh if it is hot miss at idle you can turn truck off start back up miss is gone getting 20 mph on fuel runs strong cleaned all grounds run fuel cleaner through it sometimes go a while no miss then it will miss i no lot of folks having same issue don't mind spending money just want to apply it in right place sorry I'm not very good at fancy writing. Maybe i need to convert it to a p pump.Thanks
  23. Hello I'm going to buy new injectors will my auto tranny in my 2002 be ok with the rv 275 injectors i don't miss treat it just drive to work pull small trailer if so where best place to buy bosh injectors thanks.
  24. Will change injectors soon how are the bosh rv 275 marine injectors . And thanks.
