dchunter44
Everything posted by dchunter44
  1. Okay. Well in a race tune, what is a rough idea of what you want it to do? Is there a good base map I can use to edit that will get me a bit closer than starting from scratch?
  2. I believe 3.55. I just downloaded the other mid injector tunes that I could find on here. What parts of those tunes will I also have to touch to modify them for my gear ratio, tires, elevation etc.?
  3. I have 100hp injectors and on 35s. I have found a lot of tunes on here but not a mid size injector race tune. 1999 2500 5 speed swap with 7x.009
  4. What is new in the update for iPhone? Mine works just fine...
  5. All you have to do is Download file on a WINDOWS computer. Then email the file to yourself. Open the file using the GMAIL APP not using safari. Then click on the file you emailed yourself. Press on the share button. Slide across until you see “copy to iquad”. Works everytime. Let me know if you have a problem with it.
  6. I found out how to download and load the tunes into the quadzilla app every time on an IPhone! Comment if you want me to make a video or type it out...
