Steve31
  1. I’m running dap 100hp injectors and quadzilla and actually tore the lugs off the stock converter but over all it’s a respectable daily driver with pretty decent fuel mileage
  2. Just went to orielly got all the goodies ordered also if you google there part numbers on the tie rods moog comes up? so I guess I’ll be good for 2-3 years lol
  3. How does it perform? mine seems to lag a bit and have to tap a few times to get in the menu
  4. What’s everyone running for as screens/phones? this Samsung tab4 is crap but loving the ram mount. Thinking of amazon fire7 (it fits the this mount)
  5. Update* seems I also had a bad connection at the pump tap, Marco sent me a race tune to try out......all I can say is damn it boy!!! Ole girl broke loose a bit from a 30 roll (put default tune back in before I tear more crap lol) just wanted to give quadzilla a shout out and a big thanks for taking the time for going over my unit to insure it was doing what it should and to Marco for the great customer service
  6. Played with mine a bit today since the quad update, don’t smoke near as much makes pretty good power guess before I go any further I’ll get some studs in in it, trans has already been build 6 months ago with billit servos, anchors and converter (single disk) gonna have to play around with the quad tho, I gotta have the smoke on take off in the summer time for the idiots that sit at green lights playing on there phone ?
  7. Just plugged it back in since the up date, she gonna get a test today fo sure?
  8. Ole girl was still on the cold side but the engine load is top right, not sure why the boost is stuck on 13,laptop says 0 ?
  9. Could I upgrade to the newer T style steering linkage on the 2wd?
  10. Really? Moog used to be the go to good to know, thanks
  11. With out shaking it up? also what front end parts you recommend for a 2wd?
  12. Mine had 280ish on the stocks and idled like crap to me, we didn’t use my bodies he build a set of cores he had. ever since it’s idled smooth enough to set a beer on the valve cover, I’m gonna plug in to it this weekend and see what idle engine load and all actually is
  13. Mine were set at 310bar ...all 6 the guy was real picky and wanted the exact number on all 6 my quad should be back home today I’ll hook up the laptop and check the above and post it
  14. Ok I can tell you I was there when my injectors where assembled pop pressure is spot on at stock guide lines with dap 100hp nozzles
