wyelkhunter
  1. Yeah all I see is a X also. But here's the skinny. This is what we in the HVAC field call an ice cube relay. The bottom two connectors are your coil. The second from the top, both left and right are your led or input legs. The top two, left and right are ether NO or NC contacts. The third from the top, both left and right are also NO or NC contacts. You can verify which ones are you NC and NO contacts by takeing an ohm meter from the second from the top connector to the top connector, and third from top connecter. The one that gives you resistence is your NO contact. The other will be your NC contact. This is done with a non-energized ralay. Make sure your coil leds are 12v and not 24 or 120v I hope this helps. If I didn't explain well enough, let me know.
