Feral
  1. Thanks for the quick replies guys! That's good news, I will clean and inspect them all. I have some new terminals in the mail to replace the melted one.
  2. On the way into work my check engine light came on then turned off and I saw that the alternator voltage was low, around 12.5v or so. I tested it running at work and it was about ~12.5v. I then noticed that the positive battery terminal has melted on the cable coming straight from the alternator. Would an alternator going out cause this? Bad connection? Low battery electrolytes Any ideas? The alternator has never been replaced. Thanks!
  3. Hi all...I am getting ready to do the W-T ground mod and have a few questions. I have an early model 1998.5 and the alternator is wired a bit different from the later models. I was able to find a picture of the connections from a member on here and also a wiring diagram of the alternator. Do I remove the B+ cable on both sides of the junction block all the way to the PDC or just where I placed the red arrow? Then do I run a new short B+ cable from the alternator, with 140 amp fuse, to the passenger side positive battery terminal? Is everything the same for the grounding mod after this point? Thanks for the help!
  4. Great idea...I am going to do this also!
