J_Harms
Everything posted by J_Harms
  1. To get a list like Mopar1973Man does on linux, in windows you can use Devcon.exe through the command prompt. I think this is the right command : devcon hwids =usb You can download this from https://docs.microsoft.com/en-us/windows-hardware/drivers/devtest/devcon At least it would let you know if the computer can see your tuner.
  2. My understanding reading thought the flashing guide, is it is the same software and driver for the XZT or Adrenaline
  3. Just got my new Quadzilla installed today, should have done it some time ago. Just one thing I did not see mentioned in the instructions for the IQuad or anywhere else. On the IPhone you should change the wifi settings for the IQuad. It should be set to manual instead of automatic in the Configure IP setting Set the IP Address to (in my case) 1.2.3.14 the Subnet Mask to 255.255.255.0 and leave the router blank This will allow the Iphone to connect to the Quadzilla and maintain LTE connection for interrnet.
  4. Just got my new Quadzilla installed today, should have done it some time ago. Just one thing I did not see mentioned in the instructions for the IQuad or anywhere else. On the IPhone you should change the wifi settings for the IQuad. It should be set to manual instead of automatic in the Configure IP setting Set the IP Address to (in my case) 1.2.3.14 the Subnet Mask to 255.255.255.0 and leave the router blank This will allow the Iphone to connect to the Quadzilla and maintain LTE connection for interrnet. View full Cummins article
  5. Just got my new Quadzilla installed today, should have done it some time ago. Just one thing I did not see mentioned in the instructions for the IQuad or anywhere else. On the IPhone you should change the wifi settings for the IQuad. It should be set to manual instead of automatic in the Configure IP setting Set the IP Address to (in my case) 1.2.3.14 the Subnet Mask to 255.255.255.0 and leave the router blank This will allow the Iphone to connect to the Quadzilla and maintain LTE connection for interrnet.
  6. Thank you, I am hoping that may get me the info I am looking for EDIT; It would seem to be a 62/65/12 I have no idea why I was having such a hard time searching for it.
  7. Not it but thanks, I should have included some more photos. I know it has a 60 something inducer and a 12cm housing. Had the heater core fill my glovebox about a week ago and just trying to regather the info I had stored there. I think it came from Gillett Diesel in Utah, so far my email to them has gone unanswered.
  8. I could use some help figuring out what turbo I have. I use to have the documentation that came with it but it got destroyed. The shop I got it from 3 years ago is closed. I have included a picture of the tag.
