Voltronics
Everything posted by Voltronics
  1. Will the adrenaline help regulate fuel from the hot rod vp44?
  2. Can’t find any serial number or anything for the schwitzer compression side and the exhaust side of the turbo is a bd brand with no markings either it does have an hx40 down pipe on it though
  3. The turbo I have is a 60mm schwitzer turbo 150 ddp injectors and a hot rod vp44 I bought the truck with all of this and all have less then 6k miles I’ve driven the truck for about 1k miles and notice the turbo doesn’t spool past 8psi until about 2k rpm is this slow? Also the most the turbo has spooled too is about 25psi because it runs out of rpm and smokes really bad down low in third fourth and fifth gear
  4. One other question would these injectors and the hot rod vp44 cause the engine to crank over a couple times before starting?
  5. Thanks for all the info I really appreciate it I’ll look into some dap injectors
  6. Who’s injectors would you recommend then and what size?
  7. Would the 60mm turbo be too small creating more smoke? Would a 63mm or even 62mm be better suited for the 150hp injectors and hot rod vp44
  8. I’m thinking of getting an adrenaline would that help significantly when or if I can tune it right
  9. The injectors were put in last year with the hot rod vp44 the turbo is a Schwitzer I can’t find the part number on it but the guy said it’s about a 60mm
  10. I just bought a 2000 2nd gen cummins with 150hp injectors Owner said it has an off brand turbo that’s 60mm and a hot rod vp44 it smokes very badly down low and I can’t figure out how to reduce the smoke
