OldManLogan
  1. Well my dash is cracked but not sure about replacing it, the prices are ridiculous for replacement. i know at full temp its barely blowing hot air, was gonna replace the thermostat also, im going with a spectra premium. is it necessary to replace the evap at the same time.
  2. I have a 2001 Dodge Ram 2500 I have a brown substance coming out of the floor vent not to mention when I turn the heat on I smell antifreeze and my window steams / obviously I need a heater core. My next question is how difficult of task I have done heater core before on an S10 as far as brands should I stick with Mopar or go with something else
  3. Probably a stupid question but will this work on a 2001
  4. Fuel pressure is 19, originally it had a mechanical Isspro, but it was leaking so I replaced it with an electric still at 19 pounds with current setup. this pic it looks like it goes from the bottom other stock fuel filter to the pump I just need to go from the airdog to the fuel filter, or something similar to this would Eric have everything I need
  5. This is my current setup. 1st pic is the line going from the airdog to the pump. 2nd pic Im not sure where the banjo fitting goes to if it was the old one off the pump.I just need to know what fitting i need to go from the airdog to the stock fuel filter housing and from that to the pump thanks
  6. Mopar1973 how did you run your setup any tips greatly appreciated please or a link or how to thanks
  7. would it make sense to utilize the stock fuel filter to keep the fuel heater and wif sensor or would the stock housing restrict the flow of the air dog pump
  8. I have a 2001 Cummins with a air dog 150 gpm i have the stock fuel filter housing still wanted to delete it so I had easier access to change the oil pressure sensor, not entirely sure what the previous owner has down to the truck, i believe the air dog runs directly to the pump not sure if i does or can run thur the stock filter housing would like utilize the wif and the fuel heater if possible what can or should i be looking for please greatly appreciate it
