jman
  1. @JD435 How are you liking the front coils now? Did it raise the front too much in the end vs. stock?
  2. Do all the Quad v2 tune files here monitor and adjust acc. to Intake Air Temperature, Coolant Temperature and Engine Oil Temperature or just your tunes? I'm looking to run a setup similar to what you used to run, Mopar1973Man: bhaf, 4" exhaust, hx35 stock with boost elbow, rv275 injectors. Mostly daily with some towing.
  3. Do you know if the Quad XZT+ overcomes those limitations? (They advertise it as monitoring more parameters, but they do not specify in any literature I've read).
