paradisepete
  1. Hey..I know its been awhile but I gave them a call and they toke care of me..The computer I got is working flawlessly..Just wanted to say thank you for the point in the right direction
  2. Hey LorenS..I may have gotten a lot more done but sadly I'm still trying to figure out how to be in 2 or 3 places at once?.....and would you believe me if I told you I was going to pull apart my only running 550 to do this with the thought process of "I'll get it done in about 2 weeks"...thank God I didnt do that.......maybe I should have bought a 6.7 powerstroke but I get this border line insane obsession of always wanting to be able to fix my own crap in a moments notice........ and have you seen under the hood of those new 550s?.......and I should proof read more.. Popping out the old body mounts for a set of S&Bs Got the Airdog installed...picking a spot toke awhile due to the fact there will be a hydraulic tank and hoses in places under the cab that I can't deviant from so this spot on the rail is the next best thing...I'll fab up some sort of cover/shield for it....install was pretty straightforward just had to get about 20 more feet of hose due to the longer chassis... As for the alternator belt this the one that worked for me....and once agian I know they say all swaps tend to be a little different and those guys at DCS have been good at answering my questions.. Picture of the pacbrake installed..pay special attention to the bands that clamp the turbo to the exhaust brake(when I bought the turbo I told them I wanted to run a pacbrake direct mount setup...it has its pros and cons) and the band that clamps the exhaust brake to the down pipe as well as the flange that is welded to the down pipe that will mate to the exhaust brake...I didnt find a one stop shop for those items so pay attention.. Just got a new toy.. dont tell my wife..
  3. Thanks..I'll give them a try and let you know how it turns out
  4. Hey guys..I'm curious to know if there is any auto computer builders/rebuilders that could accommodate people like me who did the auto to manual swap and would like to change both the pcm and ecm ...if I'm not mistaken cummins or the dealer wants a vin number before they sell to you.
  5. Getting the zf6 ready ....I had a TERRIBLE experience buying this unit......if you guys want to know the story I will tell it.. ..I hate bashing people's livelihood but when you tell someone what you want and that your willing to pay for it and they still give it to you with no vaseline ...maybe that's why there was no core charge on the transfer case... Damn!! Got to starting hitting the weights again....and also I need to buy a smaller transmission Jack..borrowed this one from a friend but it's for the larger Roadranger units...had to get creative with the strap binders to pull it into place Casualty or war!!! Clutch pedal...all the holes are there just have to bolt up Clutch pedal installed and brake pedal shaved down.....on the edge of the brake pedal where I cut it I took the mig and built back up the edge so the side has some kind of support for the rubber cover to make it feel firm under your foot...... What can you see in this picture?? This is when I got the wiring harness back...then I stuck it o the engine..take your time with this part..it toke me 2 or 3 time to get it I to a position o liked Installed the the alternator with the diesel conversion kit..the belt they said to use in the instructions was too short my build so I bought 2 more belts to guesstimate which one would work... Power steering!!! Factory line was some type of aluminum alloy so I couldn't bronze the hell out of it so I bought a speciality fitting from an online hydraulic store..it was a metric thread to a sae or jic flare...the truck I got the engine out of already had the a sae flare bronzed onto it so I just got a high pressure hose made up and it on.....also the power steering pump is a psc motorsports pump that was turned up so to speak for the ford application but not an exact match but it will work I was told ..this is a long topic so I'll move on This is the down pipe I'm using...I bought a MBRP exhaust system for my f550 and modified the down pipe to work with the exhaust brake..I fits really well...but it to me about 3 days just to get the exhaust system installed in a way I liked so let's hope it works well tooo I've got the brakelok to install, the body mounts, the airdog, the drive shafts to fab up or purchase and the list goes on...... Also I bought a radiator from bullet proof diesel and was told that it will only work with an auto...to make a long story short my manual transmission cooler lines snap in very snugly and I can't see a difference in the auto and manual lines when it comes to the connection at the radiator...if it leaks I'll let you know..... Look guys...I found another 6.0..any takers. Just joking..my other 6.0 works like a beast ..when it's working but that was after about 18k I dropped on it.....any ways I'd like to say thanks to Me78569 for any help and I'll be knocking your door In a few when it comes to that quad...and everyone else ..you too Evan..made me buy that turbo even quicker when I saw your setup......but not to sound greedy but now that the engine is in and I see the space I have I kinda wish I went with compounds...just saying..
  6. Hey Guys..I know its been awhile but here is an update for that project I started if your interested..and I'm not the best at this documenting as I go..I just zone out into the work.....had to pull the head on the doner engine due to a very small crack in the head .....I dropped and o-ringed head and studded it Here is a video of the engine with the new head but old injectors and turbo first start up 20190718_142557.mp4 Getting ready to pull it out Pulling out the 6.0 ...I'm going to save the injectors out of this and donate the rest to someone I dont like? Cummins on the hoist...just changing the oil pan, front and rear seal , front cover gaskets while it's out and adding the Diesel conversion parts FINALLY...dropping the engine into the truck..by far the easiest thing to do with this swap once you have the kit...felt good seeing this....top of the world Mom!........just saying Popping the new mach4 injectors Broken boost fitting ...Thanks fedex..no seriously..thank you fedex because it's usually worse Just dropped in the new injectors and the hamiltons HD pushrods..there a little longer so you will not the difference when your setting the valves.....I upgrade the valve springs due to the exhaust brake I'm installing so I just did the push rods as well It's an automatic truck but I'm putting a zf6 into it.....I couldn't find a donor truck to get the floor so I'll just chop this one up and fad it back together when its time.......the crossmember was easy enough but I saw this on another guys build ..I believe it was " twin turbo 12v build" he way better documenting skills than me and it's a fun read Installed the clutch and I had a huge surprise!!! It seems dodge does not use dowel pins in the flywheel to center the pressure plate!!...the pins do more than center the pressure plate..it also helps to hold the torque being applied......I hope I'm just being paranoid.. Another picture of the cross member from the under side
  7. Sorry...I was just showing the example of having an engine mated to a transmission that just maybe not up to the torque requirements of said engine, Maybe not the brightest thing to do but what worked for me was not allowing the engine to "lug" when loaded..I understand that's not a "pickup" engine or situation but Im sure the theory transcends....Mind you I dont drag or sled pull and of course if you beat something hard enough Its going to break sooner or later ....hence why I just bought a transmission but still on the look out for another one..... Merry Christmas!!
  8. I bought a rebuilt unit....I was looking for an outfit that sold beefed up units but didnt really any find ..The clutch i have is the single disk south bend that comes with the conversion kit.......Ive already made up my mind to stay on the lookout for another unit..I didnt realize the general cost of the zf6 and I assume You cant buy a Brand New one from ford......I had a 3406b cat with 13 speed transmission that was way under rated for that engine but I just avoided lugging the engine and It lived for a pretty long time...
  9. Hey Guys, injectors and turbo on order..Ill probably grab the Quad for x-mas.. Still need the to get a few more things like the Airdog and such..Not sure if this post is the spot to update you guys when I start but Ill try..
  10. Now that looks like a Christmas gift anyone would love......I can just imagine my wifes face when she sees this big heavy box under the tree with her name on it .... Looking at the picture Ill have to make sure it will fit with the dps conversion exhaust manifold I still have to confirm with Me78569 if its the 62/68/12 sxe he was talking about
  11. hello Me78568, appreciate the input. Just so you know im not really stuck on any particular injector size or part for that matter but after going through the threads Ive found that the 150s come up often.. Ive also seen a lot of your remarks as well as others on the Quadzilla and it does seem to be the most flexible of the tuners. Im not apposed to a quad and that may very well be the way I go but the last time I messed with an aftermarket ECU (haltech E6k) was about 15 years ago and i still remember the countless rookie hours I put into it trying to tune it without a dyno and after all that I still had to sail the car to Puerto Rico to get it on a dyno ( there is no dynos on island)..I know thats been a long time ago and im probably comparing Apple to Oranges on those tuner/programmer but I do know I have to be prepared to invest some time hence my reasoning for considering the ts/tst stack.... ..I also should have said that peak power is not really my goal but useable power........ As for the the 62 SXE mentioned I assume you are referring to the SXE 62/68/12 i can find at DAP?
  12. Hello Guys, This is my first time posting but Ive been a long time lurker. Im about to drop a 24 valve vp44 engine into my 2007 F550 superduty I'll probably start pulling the engines in Febuary. Ive already started to order parts for the swap but I would appreciate any help in pointing me in the right direction When It comes to the Tunner, turbo, injectors.... A little info on the chassis and what it will be doing...The Chassis is a 2007 F550 with a manual ZF-6 transmission 4x4. It is Roll-off truck that I haul dumpsters with and Ive hauled loads up to 10,000 - 12000lbs but the usual is around 8000lbs... Im located on an island in the Caribbean that is about 32 square miles so there really is no Long stretch of highway here but Im always going up a hill or coming down. The 24 valve engine has about 125xxx miles on it. I just dropped on a new o-ringed head with Hamilton 103 valve springs and Heavy duty push rods and Head Studs. Ill probablyad an exhaust brake at the end of the build...Also I dont really have a HP goal but if I had to put a number id say around 500hp. I was considering a ts mvp/tst powermax stack with 150hp F1 injectors and Dps fummins compounds or a Dps 62/65/12 single, What are your thoughts?... I would love to be able to drive the truck and not baby the pedal to much for concern of clouding the road... Sorry if my thoughts are all over the place... Happy Thanksgiving!!
