ramchrger32348
Everything posted by ramchrger32348
  1. Couple of comments.. I had to replace both bearings in my 3500 at 135000 miles because the axle ujoint went out. The bearing were ok,but pulled apart pulling them. The abs sensor should be removed before pulling the bearing and it can be used again. There is no adjustment on my 04.5, Actually, I pushed one bearing back together, bought a new sensor $69 at NAPA and its been working fine. If you don't have the tools or expertise and rely on someone else/shop you might want to get a good bearing. I also believe the bad rep these bearings get are do to improper installment. I was in the light truck business for twenty yrs. and I was repairing ball joints and axle ujoints let alone bearings on 4x4's with a lot less than 135000 miles. It's relative.
  2. I have the juice and CTS. when I first installed it I noticed surging at a lite throttle went accellerating. I called and they had no answer. I just put in new injectors and have not noticed the surging. The only thing that may have improved. With the juice, injectors,,AirDog, and a cost of nearly 4grand, I have not gained any fuel economy. Power is not an issue. Not what I was after. Now if I set it up to 2 and step on it, it moves out, but egt's jump past 1340 almost immediately.
