Epr2x10
  1. @Mopar1973ManI’d like to hear your idea also if ya don’t mind ??
  2. Thanks for the info. I’m looking into the Timber. Heard nothing but great things about them
  3. What’s up guys? I recently had some issues with my truck which caused me to pull codes on it. When I did that I read the “diagnosis” on 2 different handheld OBDII scanner. Both of them were showing around 13% on the apps or tps. I have tried to mess with it to recalibrate it before but when I do mess with it, it throws a code and the CEL comes on. I have noticed that I have to pushed the peddle further than I should to get the truck to accelerate. It is an aftermarket APPS that is on the truck. Back when I bought the truck I assumed it would solve my ground/ lock/unlock issue. Then I realize that had nothing to do with it and never switched it back to the factory one because there wasn’t anything wrong with it. My ideas on where to begin to get better throttle response And/or recalibrate it so it isn’t showing anything when I’m not on the peddle? Thanks Chris
  4. So I looked at the ground ring terminal for the FASS and it was chewed up pretty bad. I clipped it and replaced it, cleared the code with my cheap scanner and turned ignition on and off a handful of times and fired it up. Seems to be ok for now. This morning the CEL was on but it fired right up and allowed me to drive to a local auto parts store that had a really scanner. I shut the truck off, they scanned it, told me the code and it fired back up allowing me to drive home. Maybe a total of 5 miles with no issues. I’m going to let it sit for a little and see what it does later today. Hoping that was the issue
  5. So it’s throwing a 1689 code. I am in the process of doing some research on where to go from here...
  6. I’m pretty sure when I turn the ignition on every light comes on for a brief second then goes off. I’m going to try and take it to a local auto parts store and see if they can tell me exactly what code it’s throwing. Hopefully a local auto parts store will be able to help me figure out exactly what code it’s throwing. I appreciate the response.
  7. What’s up guys? I’m at a loss and like most people, I need to try and get this figured out ASAP. Trucks a 2000 auto. About a month ago went to fire the truck up and check engine light was on and would just crank. Wouldn’t start, just crank. Felt like it was cranking as it (batteries didn’t seem low). I posted something on a different websites and was told to check the batteries and charge them. I did that and truck fired up and check engine light went off. Flew home today for work and went to start my truck at the airport and the same thing happened. Well I purchased a cheap $30 scanner to keep in the truck. It said there was a code being thrown but it wouldn’t tell me what the code was. I think it’s just because it’s a cheap scanner. Anyways I cleared whatever code was thrown and the light went off. Turned ignition off then back on and light came back on. Cleared it again and was able to start the truck. Truck ran fine for 10 seconds and shut off. Finally got it run and let it sit for about 15 mins. I got on the road. I live about 55 miles from the airport. I got 5 miles from home and the damn thing shut off while I was doing 70. Check engine light can on. Was running fine until that point. Pulled off the road, turned the truck off and took my key out of the ignition and the check engine light stayed on with the key out of the ignition and the Edge programmer I have (Older JWA w/ Legacy monitor) was still on. I disconnected the batteries. Reconnected them and fought the same issue. Crank but wouldn’t start. Gave it a few mins and finally got it started. Drive home with the check engine light on. I don’t even know where to start. Both batteries are fully charged since I drove 50 miles, I checked them when I got home with cables disconnected and they were both 13.1. Truck has the edge and a FASS 150. My initial thought was a fuel issue which is why it was cranking but wouldn’t start when I first had the issue but I charged the batteries separately and the issue went away until today. Any help would be greatly appreciated guys. Chris Foster
