kamododragon122
  1. when i bought the truck about 4 months ago it had a reman new transmission in the truck , fluid is clean , i haven't had a change to bring a scanner home from work to check for codes and the fluid color is bright red , its not dark or burnt smelling at all
  2. hey guys i currently have an issue with my truck, i recently replaced the intake pump and injection pump and it has been fine all the way up until now . yesterday i was sitting at a red light and the truck started pouring out black smoke and felt like it wanted to take off. so i put the truck into neutral and when to put it back into drive then it shut off, it did this about 8 times then i got frustrated and held my foot on the gas and put it into drive and took off. it does feel like its under powered now almost like in limp mode.
  3. yah i went into the other modules in the computer and found a low voltage code in the transmission computer . cleared that then took it to the store same conditions happen but this time i have the p0216 injection pump timing failure what is the WT and pcm protection mod like what do you have to do for this ? and how would you check for the ac noise with a scope ? i reallie don't know diesel too well .
  4. i was checking for codes with a snap on scanner i am a technician i cleared all codes then went for a ride , and i have another code p0216 injection pump timing failure
  5. hey guys i have a 1999 dodge 2500 24 valve , at times if your are in the throttle above 2000 rpms the engine just cuts power then u have no pedal response even if you push it all the way down , but how ever if u let up for a split second the power comes back like nothing has happened at all. i do have the code p1693 in the computer i have not tried clearing the code yet . if any one can point me in the right direction please let me know thank you.
