SmokinGator
  1. I had this issue several years ago and found that the metal fuel line behind the tank had rubbed enough to wear through with a small hole where it ran along the frame. I kept thinking I was running out of fuel because my gauge doesn't work (though I manage with odometer quite well). Cut out and replaced with some rubber fuel line - problem solved since then until now. I'm actually having a hard start issue now after low fuel and am getting ready to run through and replace all of my fuel lines.
