retired01
Everything posted by retired01
  1. definately going to change over the dash and harness, I do like the look of the older dash, but It wouldnt fly with the gauges being a gasser and all. just hoping that my dash doesnt crumble to pieces like the older 96 did, the slightest bend caused it to crack straight through. thanks for the info everyone.
  2. Try this one, I just talked to Jeremy from Quadzilla and he said that should work. good luck. XZT+_1000 http://www.quadzillapower.com/products/index.cfm/p/XZT-Dodge-Trucks-USB-Updates
  3. thanks a whole bunch! I was hoping on starting it soon, but the weather aint good here in good OL' CANADA
  4. Hi I just went through all the same things as you, I also have the Quad xzt+, On the quadzilla website you can download some stuff to your module for free that actually gets rid of the surging, and if that doesnt work then you should check out BD diesel, they have an APPS noise isolator (only for automatics) that takes 10 seconds to install, it has to do with the tranny computer picking up some frequencies and making the tranny shift funny. I hope that helps you or anyone else for that matter.
  5. Hello all;I have a simple question, that may not be a simple job, but....I am in need of a new cab, instead of spending all the time cutting and welding new floors, rockers and cab corners. I have a really good deal in front of me, it is a cab from a 1995 ram gasoline, now I have a 2001 ram diesel, are the cabs interchangable for those years??? If so are there any suggestions to make my job go smoother, is there any drilling or cutting??? or if anyone has done it before what was the order they went in for taking things apart? Thank you very much.
