supachaged
Everything posted by supachaged
  1. I use a little WD-40 and put a few of those desiccant bags in the draws as well.
  2. I was going to use the Dodge manual but was not sure if being used in a different application if the wiring was the same. I can tell you that the wires are not the same color for the engine harness on this ford as they are for the dodge. I need to run a relay in between the ecm and lift pump. Thank you, I will use the pinouts from the dodge manual and the diagram you gave me.
  3. Hello everyone, I am in need of an ECM pinout/wiring diagram for a 2002 5.9 isb that is in a 2003 Ford F-650. Any help would be appreciated.
  4. Hello everyone, need a little help. Was wondering if anyone has used a used ECM in their truck if the original failed,i can purchase a ECM from a 99 3500 5spd 4x4(mine is a 99 2500 auto 4x4),but what i can gather from TSB 18-033-04 the ECM part# is the same for 981/2-99. I have CODE P1694 and my truck has a 10-15 sec delay till the Wait To Start light comes on and then i hear the lift pump prime.I imagine that i would have to have the ECM reflashed which i can get done. i can get it for a great price.
  5. Yes sir mine did to just looked at it today,and mine is a 99. Im ordering the Big Line kit. i want to get rid of all my quick-connect connections. i think they are the reason my fuel pressure fluctuates so bad(0 psi-25 psi) and also the AD pump, but according to pureflow The lift pump is not the problem. On to more diagnostics i suppose.
  6. Thank you for the reply. my problem is that my AD did not come with any extra fittings except for barbed tee's and the fittings for the pump and module only.I will check various venders and find some fittings to make this work. Once again Thank You:thumbup2:
  7. Was wondering what fittings are being used with AD or FASS fuel systems to keep the stock filter housing in line.I live in the northeast and would like the security of having the fuel heater,also an extra filter cant be all that bad. I have a AD II 165 1/2 fuel line with quick connections and modified fuel canister(which im having problems with since ive installed but thats another story for another time).
