help with wiper motor
Please consider my previous post.  It used to be...  maybe still is...  that wipers were hot (power to them) all the time.  The parking feature required the GROUND to be interupted when it reach the park position.  So YES, you will read POWER on the GROUND line when you have you meter or test light to ground.   The SWITCH is also on the ground side, so your tester is jumping the switch.
This set up sometimes causes a corrosion problem (green verdigris) on the hot side.  If contaminates like salt air condenses on the hot side.
Edited by flagmanruss
flagmanruss,,,i think i see this now after looking at the wiring diagram closely, YOUR RIGHT  Gnd breaks in certain spot which causes them to park looks to me that the only other thing that could be causing this is the relay stuck over an when ground is broke on park, the relay post should be in posItion 87,,if it was Stuck on the 87A it would short would it
IDK,,,what do think
Edited by rburks
Got in a little early today and just popped the hood. Wiper arms are clean and free to move. Removed the relay. With switch off, key on, I have 12v on wire #2 (as labeled on motor) Blue Wire. No other voltage. Tested at the plug.
Switch on low - I have 12v on wires 3 & 2 brown and blue wires. Tested at the plug.
With plug connected, key on, switch on low, I have
12v on wire 3 brown
12v on wire 2 blue
0 v on wire 1 green
12 v on wire 4 red
12 on ground
