Ok so I did the radiator flush the other day and also replace the thermostat . And today when I was making the crankcase breather I saw a few drops of antifreeze on one of the bars of the suspension right below the belt ,so I cleaned it and took it of to pick up the fuel sending unit and when I came back I took a look at it and saw the same drops I follow the leak and it looks like is coming out from the gear cover and like a small hole thats above were the oil pan and the block meets ,thats were I think is coming is there a particular place they leak need some help please?
Check the bottom side of the water pump and see if it is dripping from there. That is the most common place to leak. only 3 bolts and an o-ring to change the pump. Takes longer to drain and refill coolant than to swap the pump.
