Hey moparman hello from PA I ordered one of your high idle switches from you about 2 years ago I'm having a problem with it now and winter is on its way its taking my intake temps and ect tems and making them -40 and throwing a check engine liklght I took the loom off to look for open wires but have found nothing I was wondering if there's a way to order another one from you
Is it the single knob series? It appears that you got a short to ground which will throw lo volt codes for both. Double check your wiring and make sure nothing is cut on sharp metal or pinched.
I can attempt to do repairs on it if you send it to me.
