Had a booboo while trying to adjust my kick down cable
Went to adjust my kick down cable and add I was removing it from the housing I forgot to reinstall the clip. So as I was pulling the cable out the plastic cover that holds the cable popped out.
Well I got it back together but now it needs adjusted because when I come to almost a stop my trans doesn't shift into first unless I give it some fuel.
My concern is which way I need to move the cable. Do I move it back towards the firewall or keep pulling it forward?
What started this is the fact that sometimes under wot it wouldn't shift it would max Rev and then defuel and sometimes while passing it would downshift and not upshift.
Now while driving normal or letting of just a little bit it shifts fine.
Anyone have any suggestions?
  • Replies 2
  • Views 1.3k
You need to move it towards the firewall one or two clicks and see how it feels and fine tune from there to your desired shift point feel.
