replaced all the seals in the pump along with a new psc power steering pump bout 8000 miles agonoticed yesterday a tiny drip on the drive way, wonder what I did wrong, everthing was good and tight, or are these seal manufactured in china?, was a Gould pump kit
Thanks,I am going to tighten it up a tad, I wondered the same thing,but there is a little oilon the vacume pump[where that bushing holds the seal in,] looking from the bottom, do you think the oil could blow onto it and looks like the seal leaks? from the return line?
