Went to adjust my parking brake and found out they don't hold to well covered in oil. Go figure right? However no oil on the wheel or tire. I'm not 100% its leaking now as it could have been replaced and not cleaned off. Anyone replaced these seals before?
  • Replies 1
  • Views 1.6k
I have replaced them on my 1992 is basically the same floating axle except for the drum versus disc brakes. Only when I put new ones in I had them backwards. So make sure you put them in the right way cause yours might be in the wrong way. They get damaged when backwards, so new ones are what you want.
Taking pictures of the way it all goes back together is good.
Edited by JAG1
