2001 24 VALVE 230k miles p0122 Maybe vpp
59 minutes ago, dripley said:
I agree with @Hawkez on the ECM. Pretty pricey part to just throw on and hope it fixes it. Is your WTS light delayed in coming on? A few post back you mentioned that you pulled a relay and then turned the key and the WTS light came on and it fired right up. Which relay did you pull?
I figured that the wait to start only comes on when it wants , trucks driving fine now , n actually its idling except , I was just cruising and it tried to die so I put in neutral and it literally died and started back up itself , I'm going crazy because I can't find a damn gauge , I guess maybe the stock lift pumps is going out after just replacing,  I don't get it
Btw alternator is testing good 14 volts
Well idling I could hear it trying to die so I shutoff before it did but idk what a causing it to do that
It's pointing towards the flp, but what's causing it to not send fuel
Who knows mechanic said IP  or ecm never once diagnosed further
Idled still until I shut off few seconds ago
On 9/28/2016 at 0:47 PM, Hawkez said:
Before you spent $800+ on an ECM that may or may not fix your issue, have you checked to see what FP you lift pump is putting out?  What were your results for testing the alternator for AC voltage?
Hawkes hey man my alternator with negative on battery and red on the alternator main, and I get .042 at idle. .050-60 at 2k rpms
That is VAC correct?  If so that is getting high, it should be lower than that.
13 hours ago, ItzReckless said:
New alternator same issue
Don't forget to test your new alternator the same for VAC.  Many new alternators come out of the box with this issue.
Well new one test .009-19 ?  now truck won't throw any codes but it seems that injection pump is what's messing up like it's being told to stop
My harness to pump had a tan wire inside 2 wires.and a coating of wires ?
Excuse last statement the wires I just asked because I was inspecting the wires to IP
